Page 91 of 557 FirstFirst ... 4181828384858687888990919293949596979899100101141191 ... LastLast
Results 901 to 910 of 5570
Thread: DigitalFX 4.0
  1. #901
    Low Bitrate leatherboy's Avatar
    Mar 2005
    Athens, Greece
    Hi again.
    I try all these days to find a solution about the 100% percentage when I enable the gps port in RR. The flash clock is enabled and RR never hangs. It only does when GPS port is other than 0.
    So In the menu.ini I disabled these 2 lines because I don't need them. (In menu2.ini they are enabled and they don't affect what I will write).
    L,1,0,1,1,0,0,0,12,"Arial","GPSHDG",
    L,1,1,1,1,0,0,0,8,"Arial","GPSCompass",
    So when I disable them RR don't start. If I enable these 2 lines RR starts normally. I try to figure out if these 2 lines affects the 100% load of the cpu when gps is enabled. But I can't delete them because RR don't sarts. Bingo. Any idea?
  2. #902
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Apologize if this has been adressed, I have looked. When I am in the Music player screen and playing a song, when the song ends, if I switch back to the main menu the song starts playing again from a random point. This happens vice versa ocassionaly as well. I believe it has happened switching back ffrom the GPS screen as well. Anyone have this happen?
  3. #903
    Oct 2007
    Quote Originally Posted by Dougw133 View Post
    Yes, I have seen this happen when you play a single song and let it finish. Once you start switching screens, it will start playing again from around the middle of the song.
    At first I thought I was hitting the progress bar and resetting the song back to the middle but that was not the case.
  4. #904
    Nov 2007
    PA
    Exactly what is happening...
  5. #905
    Mar 2005
    Athens, Greece
    Quote Originally Posted by leatherboy View Post
    Hi again.
    Can anyone try what I describe? I do this in 2 computers and I get the same behavior. Is this a real problem?
  6. #906
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    No problem here. I'm running a flash clock and the GPS port is set in RR..CPU load is around 10% normaly.
    If haven't done this yet, delete ziplocator.dll and zips.dat from the RR folder (if they are there).
  7. #907
    Oct 2007
    Hi again.
    what process is using 100% CPU?
    what kind of CPU ?
  8. #908
    Mar 2005
    Athens, Greece
    Quote Originally Posted by silvi4000 View Post
    what kind of CPU ?
    celeron 1,7 , 1gb ram. RR loads the cpu at 100% but only when gps port is enabled.
    If you change these 2 lines
    to
    /L,1,0,1,1,0,0,0,12,"Arial","GPSHDG",
    /L,1,1,1,1,0,0,0,8,"Arial","GPSCompass",
    in menu.ini, does RR starts?
  9. #909
    Mar 2005
    Athens, Greece
    Quote Originally Posted by treetop777 View Post
    There is no ziplocator.dll or zips.dat. I checked it, somedays before. Thanks.
  10. #910
    Oct 2007
    to
    yes, it loads without issues
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
