Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 45
Thread: iDrive style skin || updated 24.01.2011
  1. #31
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Why have I not seen this thread before?
    It's a beauty!
  2. #32
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    That line selector could have been done with standard picture files and RR code. Each menu would have the corresponding line in the art instead of having just button art. It's actually very easy to do, just takes some planning on the menu art. I used the technique in shock skin v1 & 2, the selected button is different than the rest. It will not be as smooth as flash but it is simple to do.
  3. #33
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    BEAUTIFUL! Please continue development of this, beautiful work. I like the attention to detail in the glass orb. Can't wait to see a radio skin.
  4. #34
    Low Bitrate hongchu's Avatar
    Mar 2008
    bump... what happen to this skin... dont stop now guys... awesome skin in the making here...
  5. #35
    Constant Bitrate vull's Avatar
    Oct 2007
    could the wheel on the left be like only half visible? so there would be some more room left for useful buttons
  6. #36
    Aug 2004
    Germany
    Sorry guys, didn't receive a notification. Have to check my spam folder
    @vull
    Not possible, sorry. I would have to redesign the whole skin.
    @hongchu
    Running in my car . I made a few updates and ironed out some errors. Didn't know that there's interest in this skin. I'll upload the newest version when I find some time.
    (At the moment I'm working on a FullHD htpc skin. That has priority right now)
    @LiquidKernel
    Got no radio module, so I can't test, sorry. Also, what radio type are you talking about ?
  7. #37
    Nov 2005
    Playlist, Media Base, and Playing Immediately Command?
    Konrad, I love your skin--thanks for your work. I'm currently modifying your skin to suit my needs--specifically a keyboard only (no TS) skin. I'm working on your audio browser now and am confused by the playlist and browser objects S01 and SC02. I understand that all of the variables in these lines contain formattating information (font color, size, placement, etc.) . What I don't understand is how RideRunner knows that these lines refer specifically to a playlist and a file browser. I've searched all of your files and still can't find the answer.
    Also, is there a way to add a key command so that the highlighted song in the file browser plays immediately? For instance, if I hit 'P', it will begin playing the highlighted file?
    Thanks for such great work!
  8. #38
    Aug 2004
    Germany
    Thanks. I'm glad you like it . Guess I'll update my first post, as I did some minor changes to the skin (also a complete rewrite of MediaBase.exe). Anyway...
    SC stands for custom list, which is required for MediaBase.exe.
    If you look at the skin commands.txt (which is included with RideRunner) you can tell the difference between a playlist and a filelist:
    Code:
    /, (S) Playlist (Music and Radio)*
    /,		    FORE	BACK        PLAYED      SELECTED    SELECT FONT
    /,  x   y   w   h   r   g   b   r   g   b   r   g   b   r   g   b   r   g   b   trs  pt font
    SXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,TRUE,XX,"ARIAL NARROW:B"[,AA]
    The above tag creates a playlist view within the given boundaries, with the selected colors/font.
    AA is the Alignment of the Directory List (00=Left, 01=Right, 02=Center) -- OPTIONAL.
    /, (S) Directory, Picture List
    /,		    FOREFILE 	FOREDIR     SELECTED    SELECT           FONT
    /,  x   y   w   h   r   g   b   r   g   b   r   g   b   r   g   b   trs  pt font
    SXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,TRUE,XX,"Arial Narrow:B"
    For key commands you have to create a KeyTBL.ini
    Using KeyCode.exe you can tell the keycode of every key, which is 80 for P.
    So just put
    Code:
    080,"PLAY"
    in the KeyTBL.ini (which is in the root of the RR directory). Everytime you press P it will execute the command "PLAY". When you're on a playlist "PLAY" will start the currently highlighted command.
    You see, those are general skinning issues. I recommend you take a closer look at the "skin commands.txt" .
  9. #39
  10. #40
    Apr 2006
    Sydney, Australia
    DAB+ radio support and HQCT if that helps answer post #36
    maybe this will help?
    http://www.mp3car.com/vbulletin/hard...dio-works.html
  1. iDrive Night Red 2.17 Released
    By Enforcer in forum RR Skins No Longer Supported
    Last Post: 09-08-2010, 08:00 PM
  2. iDrive 2.20 Release
    By Enforcer in forum RR Released Skins
    Last Post: 08-03-2009, 05:03 PM
  3. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  4. SEARCH: BMW IDrive Skin?
    By toxdafox in forum RR Skins
    Last Post: 04-24-2007, 11:33 PM
  5. Custom Software Skin
    By strandtc in forum Software & Software Development
    Last Post: 03-09-2006, 09:23 PM
