Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
Thread: iDrive style skin || updated 24.01.2011
    Aug 2004
    Germany
    What the skin lacks:
    - NO iLISTS
    - NO TRANSPARENCY (didn't like how it came out)
    - NO FLASH
    - Radio screen not done
    - osk.skin doesn't have labels
    What it has:
    - Button descriptions are all labels, so this skin can be adjusted to any other language. All the variables for this are found in the skin.ini, no need to modify the skin files
    - MediaBase application: my own database software. But it should be possible to modify my skin to use BlueZX3's database software. I'm not going to do that, though . Features in 4th post
    Please note that I created the skin for ME to suit my needs. I'm open for suggestions, but I'm definately not going to support the skin as other skinners do, sorry. If I like an idea I'll see what I can do.
    In the skin folder a file called "skin_deutsch.ini" is included. Rename it to skin.ini to get german labels in iDrive3.
    UPDATE
    - Complete rewrite of MediaBase. It's alot faster now. Also you got an indicator in the top right when MediaBase is busy.
    - switched from JPG to PNG. Pictures look alot better now
    - added a second page for the main screen
    - options menu: changed options for SygicDrive and MediaBase on the fly
    - few other fixes I can't remember right now
    Attached Files Attached Files
    Aug 2004
    Germany
    Some screenshots...
    Aug 2004
    Germany
    More screenshots...
    Aug 2004
    Germany
    MediaBase
    Uses the MediaInfo.dll for reading tags.
    Although the program is working fine for me, I'm sure that BlueZX3's database plugin is more optimized and bug-free. But I like doing stuff myself, and I wanted to learn AutoIt programming, that's why I didn't use it. As I already said, it should be possible to modify the skin to use BlueZX3's plugin.
    USAGE
    MediaBase has to be run with the skin. It regularly checks for the RideRunner/RoadRunner window and will quit if not found.
    At first run a database of all mp3/ogg/wma (those are hardcoded extensions) files will be created. This takes some time, because all the tags are read and stored in the database. You can watch the progress at the audio_browser.screen.
    If you experience problems with MediaBase end the task and enable debugging for RideRunner. MediaBase will then also create a debug file in the RoadRunner music path.
    VARIABLES SEND TO RideRunner/RoadRunner
    Code:
    MEDIABASE_RESUME		resume indicator variable
    MEDIABASE_DEBUG			debug information
    MEDIABASE_BUSY			indicator variable to tell if mediabase is idling
    MEDIABASE_PATH_TMP		path for temporary files:
    				mediabase.tmp: current song, playmode (PLAY|PAUSE|STOP), screen
    				mediabase.m3u: winamp playlist
    MEDIABASE_PATH_DB		path to the music database
    See attached text file for a list of commands for MediaBase
    Newbie meatwad's Avatar
    Jan 2005
    Evansville, IN
    This looks really clean and simple. Really like what you did with the interface showing details from the main screen without a drastic screen change.
    Quotes
    "Meatwad makes the money see, Meatwad gets the honeies G..."
    Setup
    Complete = 20%
    Concept/Planning = 50%
    Purchased = ~$750
    Aug 2004
    Germany
    Thank you .
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Very nice...
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Really it's a very good work .
    Tainted Love Cris's Avatar
    Romania
    I'm really glad you will release this Konrad! I can't wait!
    Have you tried to use it with the SpaceNavigator? If not, will one be able to control the buttons in the skin with the arrow keys on the keyboard?
    Aug 2004
    Germany
    Hmm. Don't have a space navigator, didn't think about that. In fact, I don't know how to implement this in RR. AFAIK you have to use a special button code. Will have to look into that.
  1. iDrive Night Red 2.17 Released
    By Enforcer in forum RR Skins No Longer Supported
    Last Post: 09-08-2010, 08:00 PM
  2. iDrive 2.20 Release
    By Enforcer in forum RR Released Skins
    Last Post: 08-03-2009, 05:03 PM
  3. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  4. SEARCH: BMW IDrive Skin?
    By toxdafox in forum RR Skins
    Last Post: 04-24-2007, 11:33 PM
  5. Custom Software Skin
    By strandtc in forum Software & Software Development
    Last Post: 03-09-2006, 09:23 PM
