Wow, I've been off of MP3Car for a few days, and this skin is released! Looks like I'm back to being glued to the computer messing around with this skin. This is amazing! Thanks to all who had a hand in this (now I need a mic)
I have searched thru the voice commands and I cant find
the voice command for streets and trips....did I over look it??
or how can I create one...?![]()
By the way, for those that may have not noticed, Congratulations to BlueZX3 for becoming a moderator on the forums!
My Fiero Build Thread
I will have to look into the streets and trips stuff. I will did out the CD's and see if I can clean things up. I never use it personally, and the skins are probably way over due for some TLC.
As for voice commands, just have a look at the RRVoice.ini, and the way the commands work, it is pretty simple to add your own personal commands.
If you want to say "Show me my music" to go to the audio browser, just add this line in the [Commands] section. (The global section is for commands that will work on ANY screen you are on in the skin).
[Commands]
Show me my music=load;Audio_Browser.skin
Any commands in the skin name sections, will only work on that screen of the skin, and no where else.
[Audio_Browser.skin]
Show me the play list=load;Audio_Playlist.skin
Any idea what I've done wrong here?
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80010007): The callee (server [not server application]) is not available and disappeared; all connections are invalid. The call may have executed. (Exception from HRESULT: 0x80010007 (RPC_E_SERVER_DIED))
at System.RuntimeType.InvokeDispMethod(String name, BindingFlags invokeAttr, Object target, Object[] args, Boolean[] byrefModifiers, Int32 culture, String[] namedParameters)
at System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams)
at Microsoft.VisualBasic.CompilerServices.VBBinder.In vokeMember(String name, BindingFlags invokeAttr, Type objType, IReflect objIReflect, Object target, Object[] args, String[] namedParameters)
at Microsoft.VisualBasic.CompilerServices.LateBinding .LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBind ing.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at RRVehicleMaintenance.RRSDK.GetInfo(String LBL, String FMT)
at RRVehicleMaintenance.Form1.TimerStarter_Tick(Objec t sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3615 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/RideRunner/Plugins/RRVehicleMaintenance/RRVehicleMaintenance.DLL
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System.Xml
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Web
Win32 Version: 2.0.50727.3618 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System
Win32 Version: 2.0.50727.3614 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
RRVehicleMaintenance is the culprit...
Something is not right with it or .Net 2.0...
Try to reinstall RRVehicleMaintenance,
By running the Install.cmd in the specific plugins folder...
Although the error points to the .Net Framework...
I have had stability issues with this plugin...
...JJG
RRVoice Version 1.1.0.10 BETA
RRVCConfig Version 1.0.0.69 BETA
RRMouseTrap Version 1.5 Beta
RRPointer Version 1.0 BETA Update Soon
RRTTS Testing
RRScript Testing
SerialSwitch In Development
Thanks for the speedy reply. It must be the plugin... I've just spent about 4 hours on windows update installing all the .net packages and subsequent security updates. I'll try what you just suggested.
Nope, tried the install .cmd same result. Tried the uninstall .cmd and it just hangs on loading 6/6.
(QUOTE by JohnWPB) "I will have to look into the streets and trips stuff. I will did out the CD's and see if I can clean things up. I never use it personally, and the skins are probably way over due for some TLC."
If and when you and your assistant developers do get to working on S&T's, not much really needs to be done other than the fullscreen issue, a dedicated toggle button to go with it, and a embedded onscreen keyboard(which would automatically open whenever you put the cursor in a typing field by touching it..... also would be useful when using the browser).
DFX5 comes with a super user friendly OSK already, but I wish it was accessible on all screens that could benefit from one(Browser screen being one, as well as all GPS skins). Is there a way to do this already using DFX5's OSK???
...... And a menu button that would enable one to "show the desktop" when needed which would minimize RR without having to exit the program. Just some ideas I wanted to throw out there(would be very handy when interacting with the carpc)!
Linux(Learning the curve...Like when driving!!!)
Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
