Page 19 of 28 FirstFirst ... 910111213141516171819202122232425262728 LastLast
Results 181 to 190 of 278
Thread: DFX5 [Released 09/29/10]
  1. #181
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by JohnWPB View Post
    By the way, for those that may have not noticed, Congratulations to BlueZX3 for becoming a moderator on the forums!
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  2. #182
    Sep 2009
    Quote Originally Posted by locs4dayz View Post
    ...... And a menu button that would enable one to "show the desktop" when needed which would minimize RR without having to exit the program. Just some ideas I wanted to throw out there(would be very handy when interacting with the carpc)!
    show desktop is already there look in the helperfiles dfx5 help for the hidden buttons,
    .....somewhere around below the volume is the hidden show desktop, or say minimize in voice commands
  3. #183
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    Quote Originally Posted by dawnn View Post
    Will check and see...Haven't added a Mic yet...Thanks!
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
  4. #184
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Its probably a good idea for anyone new to the DFX skins, should at least skim through the help file as it points out a LOT of hidden items that one may never know exist. We certainly didn't make the help file because we like to document everything that's in the skin and how to get some of the features working....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #185
    Nov 2004
    St Louis
    A great example of which is the full screen vis - once vis is on, from the audio player, press and hold the vis button, viola!
  6. #186
    Sep 2009
    Philadelphia, PA
    Will do some exploring and reading...by the way, congratulations on the promotion!!!
  7. #187
    Jul 2006
    Quote Originally Posted by bemenaker View Post
    Good point Mitch, wasn't thinking when I posted that. I am using a Visteon HD radio. As I insinuated in my first post, I don't think this is a DFX problem as I think about it, since I got the problem in DFX4 also. This started after the August RR update.
    I do find it interesting that the bar doesn't move on the DFX4 radio screen using FWD and BKWD buttons, but it does work on the Radio screen in DFX5, just not the playlist Main screen.
    ever since the RR Aug release. DFX4 has been doing some unusual things. (one as your described)
    On top of the everything seems so much slower and things almost seem to hang.
    This has carried over to DF5 also, but haven't played with it much.
    And i doubt it PC HW related, as I have been using both an ATOM based board and DuoCore2 board.
    And the weird thing about these slowdowns is that the CPU usually sits below 5%. So its not a load issue. More of a code issue.
    Anyone else notice slowdowns with the new RR releases?
  8. #188
    Jul 2008
    First let me say thanks to all involved in getting DX5 out. I am having a couple issues that I hope someone can help me with. I am running win 7 so that could be some of the problem. When I run wifi manager it sees the availible networks but when I hit the connect button it wont let me connect to any of them. A warning opens in windows that says "Its already running". However It does not connect to the network. Another issue I am having is with the gas prices plugin. I have installed the RRgas plugin and it runs fine except that it only shows Zip code option. How do I get it to use GPS position to locate gas stations. Once again GREAT SKIN..
  9. #189
    Dec 2008
    John! voice control works!
    two problems that you might have an easy answer for though-
    1. when i click listen, the system mutes the music as it should, but when it stops listening, the volume stays at 0. so i have to shrink rr and manually turn up the windows volume each time im done speaking.
    2. edit- nevermind!
    last thing i tried was a system reboot, but that didnt change anything.
    otherwise, most of the things im installing are working out fine! im on winxp for now, with win7 ready to go when jebus gets rrvoice compatible. THANKS AGAIN john, ill donate soon!
  10. #190
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Quote Originally Posted by trader007 View Post
    whats the number code for the ~ key so i can just use that?
    1192. Check out the KeyCode.exe tool in the RR root directory. It's quite handy!
  1. DigitalFX 4.0
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-27-2014, 05:48 PM
  2. Updates to DFX5 Skin for RideRunner
    By JohnWPB in forum Auto App Mart
    Last Post: 10-08-2010, 11:26 PM
  3. Updates to DFX5 Ride Runner Skin
    Last Post: 09-29-2010, 03:44 AM
