Page 21 of 28 FirstFirst ... 111213141516171819202122232425262728 LastLast
Results 201 to 210 of 278
Thread: DFX5 [Released 09/29/10]
  1. #201
    Jul 2008
    London
    Quote Originally Posted by kbreeden View Post
    Which is why a minimize button has been located in the skin since the beginning and the section "How Do I Minimize the Skin" is included in the help file. It's a little frustrating to see people post questions that are clearly addressed in the help file.
    The help file is named DFX5 Help.chm and is located in the Helper Files folder in the DigitalFX skin folder. It is very informative.
    Edit: John, I went back and looked at the early posts of this thread and didn't see a reference to the help file. New DFX users may not know there is a help file or where to find it. It might be a good idea to mention it at the beginning of the thread.
    A shortcut is added to the start menu, under RideRunner folder > Skins > DFX 5 also.
  2. #202
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    Quote Originally Posted by TreColl View Post
    Thanks. Sometimes help files ARE helpful, but most of the time they are vague, which is why lots of newbies(like myself...and I'm actually what most would consider an advanced user) just ask instead to save time. By the way, my install is almost perfect as of now for my needs(everything works and embedes well...if only I could figure how to get DFX5's onscreen keyboard to auto launch when ever I put the cursor in a typing field(double tap on fields with drop down menus), it WOULD be perfect...don't see how to do that in the help files!!!).
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
  3. #203
    Nov 2009
    Just wanted to add some pics from my previous post of the over lapping. Also find the compus is not fitting correctly under the logo.
    Did not know if there are any fixes for these. Otherwise awsome skin and RRvoice works like a charm.
  4. #204
    Nov 2008
    I'm not having load time issues with my 2.4 gig Pentium 4. RR with DFX loads in about fifteen seconds. There were problems with the August RR release, so make sure you're using the September release or later. You will lose a lot of functionality if you use RR from over a year ago.
    Well obviously I can't use RR from a year ago with DFX5 (I was just making a point that's the last time RR loaded quickly), and I'm using the September release so I'm up to date. I also have a 2.5 gig dual core Pentium 4 with 2 gigs of ram. So it's not like I'm using a turd computer.
  5. #205
    MySQL Error
    Oct 2004
    Quote Originally Posted by Cdeldridge View Post
    Yes. Actually RR did this starting like last August. Ever since then my load time went from less than ten seconds to now, with DFX5, over two minutes. It totally drives me crazy. I know it's not a DFX thing, because other skins load slow too. I have no idea what the culprit is or how to fix it, but if someone does I would love to hear it. As a side not, I did have an older version of RR (over a year old) and it loaded really quick, but I seem to have lost the old rr installer. So...
    i can assure you its not RR...
    RR 10/1 with DFX5 loads in seconds...
    make sure your flash is up to date, RR is built on Flash10.1
    also, whats your start time from desktop to rr showing skin, on carwings_dynamic_lite
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  6. #206
    Nov 2009
    Is there a way to disable the video lock out while moving?
  7. #207
    Sep 2009
    Philadelphia, PA
    Quote Originally Posted by themlruts View Post
    Not sure how your system is wired up, but on most systems there is a remote wire that is attached to the parking brake sensor that prevents you from watching video or movies while driving(activated when the car is put into drive, and is always connected when professionals install your system...which is why I install my own....professionals HAVE to connect it usually because it is the standard policy, though sometimes you can get one of the installers to hook you up on the down low and not set up the parking brake feature). Just disconnect that wire...problem solved!!!
  8. #208
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    all i'm going to say is look at your plugins you will find it ,,,,,,, its all done by Plugin , no wires nothing .........
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  9. #209
    Raw Wave
    Jun 2002
    Virginia
    I'm pretty sure the section entitled "Disable Motion Lock on Video Screens" in the help file could be helpful.
  10. #210
    Variable Bitrate bemenaker's Avatar
    Nov 2008
    I'm not sure if they can give you detailed instructions how to bypass the lockout, since it's illegal to have video playing where the driver can see it while the car is in motion. Carputer1 really gave you enough to figure it out though.
    Or it could be in the help file.
  1. DigitalFX 4.0
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-27-2014, 05:48 PM
  2. Updates to DFX5 Skin for RideRunner
    By JohnWPB in forum Auto App Mart
    Last Post: 10-08-2010, 11:26 PM
  3. Updates to DFX5 Ride Runner Skin
    Last Post: 09-29-2010, 03:44 AM
