Well after many delays, it is finally ready for download!
FIRST and foremost, MANY thanks to the bets testers, they did a FANTASTIC job catching most of the bugs and problems, so we could fix them:
Carputer1, DaveDog, kbreeden, Doug133, Gizmo, & Jebus
NOTE: ElCamono has asked that his plugins not be used in the DFX5 skin. I have removed the plugins from the skin. You will need to download & install the plugins and get them working yourself if you intend on using them. I must also further note though, that he has told anyone that is using the DFX5 skin, that they are not aloud to use his plugins in any way. So if you do, do so at your own risk.
Thanks for your understanding.
NOTE: The skin is 100% free, however there is an option to donate $9.95 in the app store. As a thank you for your donations, you can download a patch that will remove the generic splash screen when the skin starts up, and replace it with one that more matches the look and feel of the skin. You will also be able to replace the splash screen with any graphic of your choosing.
The skin has incorporated Jebus's RRVoice plugin, allowing you to speak just about anything you see on any button throughout the skin. You will also be able to play your music with commands such as:
"Play Artist Journey"
"Play Album Greatest Hits"
"Play Song Separate Ways"
"Next Track"
"Previous Track"
"Skip Forward" (30 second jump)
The list of features in the skin is extensive, and I will edit this post and add them in the next day or so.
Here is a demo video showing some of the available voice commands to control the skin:
The skin is available in the AutoAppMart Here
To donate and remove the generic splash screen, you can download the patch here.
