does RR support ODB ??Originally Posted by evolvetech
explain a little bit more, im still mostly a RR newbie, i hang with the monkies.Originally Posted by 65coupei6
not not directly maybe as an ext app and with skinbedder but not natively
EDIT assuming u meant OBD
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
Yeah i ment odb2, it kind of got lost in all the quotesOriginally Posted by lostreception
updated download is ready
download link updated in first post
READ THE WHOLE POST and make sure you have everything, things have changed
thanks,
LS this is what I meant. You can find it here:Originally Posted by liquid_smoke
Sensor skin
and in this skin here:
Kuo Skin Release
I just found a bug in the new version. When I am in the Music or DVD screen I can not exit back to the main menu. I have only tried it in these two screens. So, I ended the task and then switched back to the default skin and everything works ok. So, I guess it is this new version of LS3.
Do you still have a previous version hosted somewhere so I can use it until this gets fixed? I wrote over my old one like a dumb***![]()
P.S...If you need more download mirrors for your skin just let me know. I run 3 different websites on 3 different servers.
you need to add the code at the bottom of exectblOriginally Posted by 65coupei6
also you need to remove the Vol- and vol+ buttons on the gps audio as the slider ceases to function unless its just the slider itself i think it might be related to the buttons but am not positive.. as well the sliders in gpsadio and regular audio are different sizes one is taller and one is shorter other than that looks great looking foward to n64 too
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
I don't know if this is a bug or not, but when browsing video files I am not getting the individual files to highlight like the MP3 files do in the audio player. I can double click the video files to play them, but I cannot tell which one is currently selected because they all look the same regardless of which one the cursor is over.
Other than that, top notch all the way.
Also, I just updated the code in the exectbl with the one you updated tonight and now I lost all the buttons at the bottom in the main menu. I didnt save the original ones but they worked better, do you have them?
