Liquid this skin gives me wood!!!
Awesome work! I say again Awesome work.
I have noticed a few things in setting it up and using it that you may want to complile into a Frequently Asked Questions Section.
1. If one either uses the default clock.fla (which if the VW emblem) or another car manufactrurers emblem that was downloaded from the appropriate site then there is a noticeable difference in the brightness of the emblem flash file when it is dispalyed on the interface so it creates a kind of light rectangual box around the flash emblem and clock representation.
This is only perceptable if one is running 16 Bit Color (65 K Colors)
Resolution: Switch to 32 bit Color (16.7 million Colors) and there is no perceptable difference in brightness of the chosen clock.fla file.
2. On the secondary menu that is displayed after one presses the lower left hand Menu Button (which is ingenous ! BTW) the last choice on the left at the bottom - Mispelling. GAMA is what is present , but it is spelled GAMMA (with 2 M's)
Resolution: ReSpell it the correct way and release an update that encompasses the fix
3. If one has the settings under Start>Control Panel>Display>Settings> Advanced Button > General Tab Under the Display DPI settings set to anything besides NORMAL (which is 96 DPI ) Dots per inch then the included fonts for the skin will display too large and not fit into the transparent areas within the skin for DATE (upper right side) and the Weather Panel Readout will also be affected and not display all of the proper text.
Resolution : Negotiate to Start>Control Panel>Display>Settings> Advanced Button > General Tab and set to NORMAL - Insert the
Windows XP CD to copy the necessary files if prompted and then do a full reboot of the system.
I am sure that I will have a few more items to add and I hope these are constructive points that can be added to some sort of reference. Actually it would be pretty great to have a HELP button on the interface that just brought up a file of FAQ's (Freaquently Asked Questions)
I can help you complile these for inclusion if necessary?
I am still working on getting
IGuidance and Skinbedder working and I am sure it is something with the path that I have set and the location that SkinBedder is installed in as well as the Window name. Can someone rattle off those settings as I may have missed them in my first read through.
Regards
E30_Droptop
