oddOriginally Posted by meissenation
are you using a com port splitter? Not that you shouldnt, its actually recommended for this skin.
have you changed anything in the skin thats specific to your setup?
Yeah, exactly. It was working fine, I installed a Wireless USB adapter and then later I noticed the GPS stopped working, and at first i thought there was maybe some sort of conflict, but I checked device manager and it's not showing any conflicts. Also, if there was a conflict then it wouldn't work universally, but for some reason this only won't work on LS. Works fine on ZDGrey, and it also works if I view iGuidance on it's own. Any sort of ideas? Really love using LS.
CarPC v3 - 6/4/2008 - Project Showoff Thread
CarPC v2 - Project Showoff Thread
Michigan FBody Association - Administrator and Owner
beer replenishment fund
mp3car live search
Using DeLorme's com port program to change the USB to a com port.
Figured it out; apparently the LS skin does not like it if iGuidance is already loaded! I'm not sure what the difference is between the other skins and yours, since they worked, but that was the problem. I forgot that last night I put iGuidance into my Start Up folder so it'd be loaded and ready when RR loads. I'm guessing since it loaded on its own, for some reason LS wasn't recognizing it. I had minimized RR and manually exited iG while I was doing some stuff on the desktop, then went back to RR and went to GPS and it worked perfectly again. So, problem solved.![]()
I have to say this a great skin!!!!! but runing in to a small problem. cant seem to load the IG with this skin. have tried to follow the inst. the bellow pic is what i get. can someone please tell me what i am doing wrong and how and where and what i need to do.
thank you !!!
thats even more odd, i have IG preloaded all the time. Are you using IG by itself or are you also using skinbedder? As you know the skin is setup to look for skinbedder.Originally Posted by meissenation
mp3car live search
Originally Posted by cali0028
well it looks to me that your paths are wrong.
download skinbedder2.9999999 if you dont have it allready.
Install it to this path
C:\Program Files\Road Runner\SKINbedder_v2.99999
Go back to the first post in this thread, there is a .ini file that is needed
mp3car live search
Originally Posted by liquid_smoke
cant seem to find the v2.99999..but did find the v3..and changed the button value to as follows
"RUN;C:\playfile.exe|C:\Music.wav||LOAD;EXTERNAL_GPS.skin;RUN;C:\Program Files\Road Runner\SkinBedder_v3\SKINbedder.exe;SKINbedder"
is this right ??
looks good to me,
note that V3 is buggy (last i checked)
mp3car live search
skinbedder2.9 is here
[Release] SKINbedder BETA 2.99999
mp3car live search
