just updateing this thread incase anyone is having problems with this skin and the latest version of RR.
If you do not have the playfile.exe file (see first post) in your root C:\ drive, RR will fail to recognize mouse input after it tries to run the said file and fails to find it.
The file is used for click sound support, and previous didnt need to be present for things to work. But now is required. Next release will not have this issue
minor update:
dual audio player mode added,zip file attatched at bottom of post
unzip files to LS3beta4 skin folder
to access the alternate audio player, click the time while in the audio player to cycle,
UPDATED DOWNLOAD AS OF 9-27-05 5:18PM
IF YOU DOWNLOADED BEFORE THE TIME STAMP ABOVE, REDOWNLOAD AGAIN.
I HATE SBC
i had a nice wrightup and everything, but leave it to SBC to drop my connection the moment i click the submit post button! argh
so now i give you the short version
anyway, latest version is up
if you dont bother to read this post, i wont bother to help you when you ask questions that are answered here.
manual here
skin
here
fonts
here
for skinbedder 2.999999999
copy this file into this dir C:\Program Files\Road Runner\SKINbedder_v2.99999\iGuidance\
note: freedrive support is not fully complete. Popup menu,zoom slider are not skinned yet
freedrive addon here
unzip into LS3.0 skin dir, overwrite files
matching freedrive skin
here
unzip to your freedrive skin dir
this is freedrive beta1 skin, ill update it based on feedback since i dont use freedrive
Car logo's you will need are found here
http://download.andgear.com/rr/skins/LS3.0/Clocks/
watch that site for new logos with speedo intergrated
WARNING WARNING WARNING
YOU MUST HAVE THE LATEST VERSION OF ROAD RUNNER
CLICK SOUND SUPPORT
download this file and place it in the root of your C DRIVE
also download this wav file and put in root of your C DRIVE
see this thread and thanks to MGD for the playfile.exe
Sound on Click?
UPDATED DOWNLOAD AS OF 9-05-05 11:00PM
Ok, here is LS3.0 beta3
a quick run down on setup and changes:
Its assumed that you have RR installed in the default path of C:\Program Files\Road Runner
pretty much all menus (minus options menu) are where i want them to be.
did some clean up in the audio player, no invisible buttons
reorder the main menu a little
added support for motherboard monitor, accessed from the options menu
Options menu will likely have some changes done to it in the future, with the added support for MBM, and also a version button, it's getting crowded
finished the games menu, this menu is setup to be used with a N64 emulator but you can change it to load whatever game you want. Project 64 can be found here http://www.pj64.net/ and if you do a search on this forum you'll find links to roms. Also configure Project 64 options>configure graphics plugin...>Windowed Resolution 512x384 or lower
Install to the default dir and it should work, if not you'll have to edit in RRSkin editor to the correct path.
The text on the buttons in the game screen are RR labels so you can edit it without changing the graphics.
The pics button in the options screen is pointed to Zorros PicViewer.net which can be found on his PhoCo download page. Install PicViewer to C:\Program Files\Road Runner\PicViewer.NET
GPS setup, if you havent gotten it working yet or this is your first install.
GPS points to skinbedder, and you will need to have it installed in this path C:\Program Files\Road Runner\SKINbedder_v2.99999
WEB BROWSER embeds firefox, if you dont have it go get it, if you dont want it, use IE. I think you just change it in RR config
Weather, DO A SEARCH FOR HOW TO SET IT UP
as with previous versions you will need to copy and past this code in "ExecTBL.ini"
THe skin uses 2 main menus, one with play buttons at the bottom and one without play buttons. Which one shows up depends on if you have music playing or not. No music you get the menu without the play buttons, etc.
IF YOU DONOT COPY THE TEXT BELOW INTO ExecTBL.ini YOU WILL NOT HAVE ACCESS TO THE MAIN MENU
Code:
"MAINLS","LOAD;menu2.skin",PLAY
"MAINLS","LOAD;menu.skin",STOP
"MAINLS","LOAD;menu.skin",PAUSE
for those who have not mastered the copy and past functions, i have provided the file pre copy and pasted for you. wipe your mouth after the download. HERE
everything else should be obvious, but if it isnt , dont hesitate to ask.
Oh, almost forgot
New Car logo's you will need are found here
have fun, i really like how these turned out.
DiNASTY put a lot of work into these
Also, PSD files will be released (likely after im done with all 3 versions of the skin)
credit goes to Zots for the volume and track sliders
credit goes to evolvetech for hosting the skin
credit goes to DiNASTY for use of his flash car logos and everyone else whos offered help in someway, THANKS!
SKIN
FONTS
post any bugs you may find or any other issues.
Ill be updating the skin on a regular basis untill im 100% happy with it and all bugs ironed out.
