Sure do - should it be the other way?
Do you have the hide mouse option set?
See my install here:
540i / 320i Mods
Get a free and lightweight blog here
iPhone Hacks
Thought Soup
Look for a command
leavemousealone=
and change it to true.
Didn't fix it - I tried every combination with the mouse settings as well. I'm back to reinstalling RR I suppose. With the leavemousealone option set to false, no matter which option it starts on, it goes directly to the settings option and then is stuck from there. Weird stuff. Thanks anyway.
540i / 320i Mods
iPhone Hacks
Thought Soup
Feature request (or maybe I just don't know) - for those of us less fortunate without a BMW, is there a way to replace the BMW logo with one of the other manufacturers? I guess I could go into the menu_* jpg files and just fill in the bmw with the background and then create a label in the menu skin so it would be a little more "dynamic." Would that be (close) to the right way to do it?
There are going to be a few menu screen options, mainly including the iDrive knob, but I could look into making it a jpg image instead.
looks left, sees he has a Jetta.
If you want VW ones, the orginal iDrive that BTBE had VW logos. so I have them here
En4cer, you rock!
Originally Posted by Enforcer
Yes. No particular shade, just one that looks good...![]()
In the rest of the menus, there's a blue bar on the right. That's the real problem as it doesn't look good with the replaced orange into green...
The blue bars I was reffering to...:
Originally Posted by DarthTater
In the keyTBL config file in RR directory, chenge the following lines
38,"CTRLUP"
40,"CTRLDOWN"
to
38,"UP"
40,"DOWN"
That did the trick. Thanks Cris!
540i / 320i Mods
iPhone Hacks
Thought Soup
