iDrive skin for Road Runner
Version 2.11
Download **** updated 08 March 2006
Changes in 2.11
Basically this is a bug fix edition.
Fixes.
correct GPS in use shown in iDrive config.
Navigation via arrows keys on main menu getting stuck.
Navigation via arrow keys (powermate) now in sequence.
MapMonkey speed display.
Spelling of Scroll as scoll.
Deletion of tracks from playlist moved to Audio Browser from Audio Settings.
Additional screen.
Valentine 1 software is now supported (basic)
Tested screen.
Phoco has now been tested and found to work. Thanks Zorro
Changes in Version 2.1
Changes
Button to go to main menu on most pages
Phonecontrol button on most pages
Slider added to video screen - DMurray request
Date moved to RHS to allow road name to go central.
Additional Screens
Mappoint
Sirius Radio - Thanks to DMurray
XM Radio - Thanks to DMurray
Hidden (ish) Buttons
Phone icon on top bar takes you straight to Phone Control
BMW logo on bottom bar takes you to main menu
iDrive Skin Configurator
In this release is a skin config.exe, which will change the GPS info source depending on whether you are using FreeDrive, MapMonkey, or RoadRunner and remove them if you are using a GPS that does not support supplying the info to external programs. This also allows to to select which options you have installed (ie TV, Radio, Games etc) and remove them from the menu's if you don't have them.
For this to work you may need to register the file PICCLP32.OCX.
You can either run the register.bat file or from the command prompt type regsvr32 PICCLP32.OCX
Changes in Version 2.0
Changes
Button over and down on LHS menu now have a 3D look.
Additional Screens
CD Rip
Radio - This is untested as I don't have a radio
MapMonkey
TV
Mobile Emulator iDrive skin
Copy the folder called emuskins to your Mobile Impact folder and edit your skindir.ini file and change path to iDrive.
Original designs and layout by BTBE
iDrive - btbe's original version
Redesign February 2006 by Enforcer
Changes from original
Pop up Volume removed and replaced with +/- and mute on every skin.
Climate button on lower part of every skin replaced with weather button.
In/Out temperature replaced with Road name supplied via FreeDrive
Track lists in Audio Browser realigned to fit in better. - Thanks to Cris for this observation
PageUp and PageDown added to track lists in audio Browser - Thanks to Cris again.
Additional Screens
External GPS is
Freedrive - Thanks to RoyN for original ideas on this
Weather from Weather.com added.
Games Emulator screen using
Red Deaths Mobile Emulator
Traffic info using
StevieG's Mobile Web
Phoco Support -
Satellite logo takes you to the Navigation screen, unless you are already there in which case it reconnects the GPS mouse
Sun/Cloud logo takes you to the weather screen
Speaker logo mutes the
sound.
Touching just above the scrolling Trackname takes you to the audio browser
BMW logo on Menu screen minimize's Road Runner.
Screens to come
SMS for phoco - if someone wants to give me skin names and any codes required.
iGuidance - This again will be untested
Draw
Rainlendar - maybe if there is a want
Main menu options of iDrive button or Cars manufacturers logo.
External programs iDrive
skins to come
FreeDrive
MapMonkey
Suggestions and comments welcome.
Please note I did not have the orginal PSD's so don't ask
