Page 37 of 55 FirstFirst ... 272829303132333435363738394041424344454647 ... LastLast
Results 361 to 370 of 547
Thread: iDrive for Road Runner - Originally by BTBE
  1. #361
    Low Bitrate bLindmOnkey's Avatar
    Jan 2004
    sdale
    i've been trying to figure this out for a while. no luck yet. Very annoying. Would be perfect if it worked. Reinstalled, updated flash, not sure what's next..Other skins work fine, but thisone works fine on every machine but this one.
  2. #362
    Oct 2004
    Toronto
    Quote Originally Posted by bLindmOnkey
    I've got the exact same problem, works on 3 different desktops ad my laptop, but not on the CarPC. As soon as I touch the powermate it jumps to 'settings' and sticks there. Every other screen the powermate works like a champ. I've been fighting this for a week now, and I've tried everything I can think of. If anyone has a solution, I'm dying to hear it...
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Guys.
    Go back to page 22 of this thread.
    make sure you have downloaded the iDrive skin from my link on the first post of this thread and not the mobile effects one as that may be out of date.
  4. #364
    Jan 2004
    sdale
    I am using the latest from your link and i still get the problem. I did notice something new though. It's not my carpc at all. It's your skin. I played around with the resolution and saw that the problem occured when I set the resolution to 800x600-on any machine. When I made the resolution higher the buttons started working even on my carpc.
  5. #365
    Jan 2004
    sdale
    one other thing-you said to fix the bug you modified the pointer position so it'd be out of the way of the buttons. When my screen res is at 800x600 the pointer goes to the bottom left corner and disappears on the Main menu, but if i move the mouse left and right while it's invisible and underneath the buttons, the selectors still moves to the buttons above the cursor. However, on every other screen this doesn't happen. Maybe you need to edit the size of the buttons on just on the main menu so it'd work in 800x600?
    also, when i launch iguidance the window doesn't embed into the skin(i'm now just pointing to iguidance.exe. and how'd you get those buttons to work with iguidance?
  6. #366
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OK, I've had a play with the resolutions on my home PC and I see the problem.
    I have been testing on resolutions higher than 800x600 that's why it seemed to work for me
    However I think I have now corrected this issue.
    please download the attached new menu.skin and replace your existing one with it.
    cheers.
    Attached Files Attached Files
  7. #367
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Enforcer
    As far as iGuidance is concerned, what is your settings in RR config?
    also does it load with other skins?
    sendkeys.
  8. #368
    Jul 2005
    NJ
    kinda random question but i have iguidance and i was wondering if i can use the maps i have for them...in Freedrive?..if not where can i get United States Maps..it seems like the front size of streets and directions is alot larger then mine for Iguidance..any ideas?
    thanks
    Jason
  9. #369
  10. #370
    Jan 2004
    sdale
    hey that menu patched worked! thanks!
    I have a nitpicky suggestion though. Reverse the left and right arrow key commands so Left Arrow will move the selector counter-clockwise while the Right Arrow will move the selector clockwise. This way it makes sense on the powermate (yeah i know i could reverse the keymap on the powermate but IMO it should be switched anyway).
    As for iGuidance I forgot to name the window so it wouldn't fit properly. Once I gave it the proper name (iGuidance) it worked.
    Not sure how to set up sendkeys. Some direction on that please?
  1. Road Runner Installation Program
    By bry21317 in forum Road Runner
    Last Post: 01-29-2008, 10:22 PM
  2. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 01:40 PM
  3. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 10:50 AM
  4. How do I install Road Runner ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 03:16 AM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 12:16 PM
