Page 102 of 131 FirstFirst ... 2529293949596979899100101102103104105106107108109110111112 ... LastLast
Results 1,011 to 1,020 of 1303
Thread: LSX (VOID) released
  1. #1011
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by itstdt View Post
    can i show both Album art and the clock at the same time on the main screen?
    NO
    beer replenishment fund
    mp3car live search
  2. #1012
    Aug 2003
    Chicago
    Quote Originally Posted by tmar89 View Post
    After I hit one of the options, I was stuck with a small gray square in the top left and nothing happens.
    for some reason it looks like the script that copies the menu.skin file from LSTOOLS/ALT isnt copying the file.
    This is reported working for other people, and i tested this specific feature on 2 other machines with no previous RR installs.
    Did you remove files from this dir?
    The script is fairly straight forward, in that it simply does a file copy from one dir to another
    The only things i can think of that would break the script are,
    1. you removed the files to copy from the ALT folder by mistake (maybe cut & past instead of copy?)
    2. You have RR installed to a non default path.
    Files that are copied are copied into this dir
    C:\Program Files\Road Runner\SKINS\LSXVOID1.5
    if you renamed the skin to something else, dont have RR installed into that dir then it wont work.
    mp3car live search
  3. #1013
    May 2004
    Quote Originally Posted by liquid_smoke View Post
    Yeah, I have it installed to C:\RoadRunner. Will this affect any other LSX VOID skin functionality?
  4. #1014
    Apr 2005
    Yeah I can see that messing it up, throw it in the default path.
  5. #1015
    Aug 2003
    Chicago
    ok, so that is the problem.
    At one point it was strictly required to have RR installed to the path i said in the previous post. This was a while ago and since then have removed all path dependencies. This new feature however does require that path to work.
    In the future please try to include as much information as possible about any issues and or your setup environment. Otherwise i end up guessing what the problem is just like you.
    This skin isnt just a skin, there are numerous scripts for different things that aren't supported in RR by default.
    Ill try to figure out a way to get the script to work no matter what dir you have RR installed to, but in the mean time if you want it to work you have to put RR to the default install path.
    mp3car live search
  6. #1016
    May 2004
    Ok, thanks for your help.
  7. #1017
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by Cruelkix View Post
    Is the volume the only thing that is lagging? Or does it lag when you go to other screens too?
    Other skins are very quick, the alpine is the fastest. This only happens on my via. my p4 carpc and my desktop are responsive. Guess its a hardware limitation in my M10000
  8. #1018
    May 2004
    liquid_smoke,
    I want to thank you for putting up with all my recent questions. I'm new to RR and your skin and I've been very impressed and I am still learning how to use the software to its maximum. I finally got everything I want working with your help and was able to reverse the playlist colors so I can see better in the day. Yeah, its very easy to change the skin around. Keep up the great work!
  9. #1019
    Aug 2003
    Chicago
    liquid_smoke,
    np,
    what colors did you end up going with? On my side i ended up changing the current playing track color to yellow, stands out a bit more than the red.
    Ill have to play with it more, the playlist is one of those areas ive never really been happy with, there are things i want to do with it but aren't supported in RR without using flash
    mp3car live search
  10. #1020
    Aug 2003
    Chicago
    Quote Originally Posted by blk02si View Post
    i loaded up the alpine skin and honestly i dont see any speed difference with anything. IMO the volume in RR with any skin kind of changes slow but its the same across the board.
    Is your carpc the p4? If so what is the via for?
    mp3car live search
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
