Page 103 of 131 FirstFirst ... 35393949596979899100101102103104105106107108109110111112113 ... LastLast
Results 1,021 to 1,030 of 1303
Thread: LSX (VOID) released
  1. #1021
    May 2004
    Quote Originally Posted by liquid_smoke View Post
    np,
    what colors did you end up going with? On my side i ended up changing the current playing track color to yellow, stands out a bit more than the red.
    I used yellow initially and it stood out nicely but then I kinda reversed the original colors so the current track is pure white and the others are red. Both looked good, I just preferred the latter. The only thing I had against the yellow was that it clashed with the red in the slider and I didn't want to have too many conflicting dominant colors in the skin. Plus, the red on the gray/black looks great at night!
  2. #1022
    May 2004
    i loaded up the alpine skin and honestly i dont see any speed difference with anything. IMO the volume in RR with any skin kind of changes slow but its the same across the board.
    Is your carpc the p4? If so what is the via for?
    BTW, I use an Epia 533Mhz board. Granted, RR runs slow but its really not that bad once you get used to it. It takes about 5 seconds to load RR, then 2 seconds to load the buttons. Music resumes. To go to a screen, it takes about 3-7 seconds once I push a button, depending on the screen. This is all without viz (small viz) on.
    The lag was really the main reason I stayed away from RR because it bothered me alot initially. Mediaengine and FP work alot smoother and respond quicker than RR. But once I loaded up this skin and played around, I was locked in. The Flash-based skins REALLY kill my performance, though.
  3. #1023
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by tmar89 View Post
    Damn, i don't think i could live with that. Im glad i didnt go the via route, i almost got one but i knew those cpu's they used couldn't possibly have any muscle. Some of the via boards suport intel chips now so that may be the best of both worlds.
    I read in one of the other threads that flash should be a lot faster now or in the near future so a flash skin may not be as slow for you as it is now. I think freedom may be using the new faster method for his skin.
    But back to the 7secs delay, seriously i dont think i could live with that. Maybe time to upgrade.
    beer replenishment fund
    mp3car live search
  4. #1024
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Via is currently installed in the stang. p4 and xenarc await unjuiced in prime running condition. I think i am going to sell my via and put the p4 to use
  5. #1025
    Aug 2003
    Chicago
    ok, i figured a way to make the visopt screen (scripts) work no matter what dir RR is installed to, so this will be included in either an updated patch or next release.
    also, started the task list for the next update on first post.
    mp3car live search
  6. #1026
    Newbie WinoOutWest's Avatar
    Feb 2005
    Vancouver, BC
    What about adding the Shuffle/Repeat button to be available in the customized buttons list? I'd like to have this on my main screen - it seems to be one of the few that isn't available.
  7. #1027
    Aug 2003
    Chicago
    Quote Originally Posted by WinoOutWest View Post
    yeah, those are left out on purpose for right now. Or were left out on purpose. With the last update i meant to add them but forgot. There is a shuffle/repeat status label on the main menu, but you wont see it unless you run the beta 9/15 release of RR.
    I just added it to the ExecTBL.ini so itll be there on the next update. I would post the file right now but its in kind of in a under construction state.
    Its really easy to add this though.
    Tomorrow ill grab the release version of the ExecTBL (on another machine) and add those commands and post just that file.
    mp3car live search
  8. #1028
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    LS have you seen this? Any way to incorporate this into your Skin? Also any update on the day skin?
    Thanks buddy.
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  9. #1029
    Aug 2003
    Chicago
    Quote Originally Posted by Civic03 View Post
    Thanks buddy.
    no i havnt seen it
    i think u left out the link
    mp3car live search
  10. #1030
    Aug 2003
    Chicago
    im working on some setup/option screens for the skin right now.
    Does anyone have any things that they change on a simi regular basis or things they would like to see that would fit under the "General Options" catagory?
    So far i have
    SETUP--runs and embeds RRConfig.exe
    UPDATE CHECK-- runs rrupdate.exe
    SKIN BROWSER-- change skin
    DAY-NIGHT SKIN-- switches to day or night skin
    RESTART RR-- exits Road Runner, waits 5secs then loads back up
    CLOSE WINAMP-- closes winamp, also starts if winamp isnt loaded
    I got room for a few more i would like to through under this catagory.
    any ideas or something you want to see?
    There will be other categories also, like Skin Options etc
    I want to do a full blown RRConfig type thing all from inside the skin, and it is possible but a little daunting.
    mp3car live search
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
