Ok so I had that correctly done but how do you pick the saved playlists?
Printable View
lost reception. thank you .. that solved the issue.
LS. thanks for looking into this and verifying this also.. I noticed ather changes in the rrconfig screen, but i missed that one. Thank you both.
there will be a new method in the next release, but currently this is how its done.
1. you want to create a folder inside of your music lib to store your playlist.
name it something that will force it to be on the top of the list. In my setup this folder is named
"-{saved list}-" without quotes. The dashes keep it at the top.
2. Set your Playlist Path in RRConfig.exe to this folder
When you are in the audio browser just go into this folder and you'll see all of your saved playlist and can load them just as you would other media.
In the next update there will be a button that will popup a screen with a list of all your saved playlist.
Thanks LS.
hey LS. i know we discussed this before. but i know your working on another update and i didnt see this listed on things to do yet.
audio controls in the webbrowser screen. volume+/- next prev and pause/play.
i thought you were going to add them before, and then things got switched to the browser plugin. just curious if your still going to implement this. Y
they are implemented, next prev and pause/play are there, no volume buttons though. The skin only supports the new webbrowser plugin and the audio controls are only available if your using the plugin.
When you click the Fav button it will reveal the audio controls.
If you were expecting the audio controls to be in the same area as on other screens etc, this likely will not happen as it would take too much screen space from the browser window.
I am having problems getting RadioShark to run native. I have followed the instructions here:
http://www.mp3car.com/vbulletin/show...96&postcount=1
and I have changed the I have replaced the radio_player.skin with the radioshark_player.skin and copied over the needed jpgs (the ones that come with radioshark that appear to have been designed for LSV). When I click on FM it goes to the proper skin but radioshark never launches or runs. Is this a RR problem of skin problem? Do I need to change something the Exectbl.ini file too?
Thanks for the help.
-GK
I dont use radioshark, or any pc based radio at all, but looking at the instructions from the link you posted , you didnt follow the steps correctly.
It says you dont need any special radio player skin,(should work with no edits to the skin) so you prob shouldn't have copied over the one included with the skin. It also says it works with radio_player.skin and dosent mention radioshark_player.skin that you got from somewhere else.
There are no special radio commands in the ExecTBL.ini or in the skin, everything about the radio is pure standard so any issues you may have is likely a configuration problem either in RRConfig or with radioshark.
It also says you have to patch RadioShark too.
i have a utility i made that will basicly setup the rr.ini settings for this skin automatically when you install the skin and any time after if you want to reset to defaults.
I need some people to test it though to make sure it does what it says on the box.
1. Backup your RR.ini file in the root of RoadRunner install
2. download and uzip the attatched file into the root of your RR install dir
3.Open RR.ini and scroll to the bottom till you see lines about 30lines that start with "MAINBUTTON1="
TEST 1
4. Randomly remove values after the equal sign
5.Save the file and run LSXVOID_DEFAULT_SETUP.exe
6. Open RR.ini and check that any values you deleted are now restored
notes: to delete the value make sure it looks like this
original: MAINBUTTON1=0
deleted value: MAINBUTTON1=
TEST 2
7. Open RR.ini and remove all lines that start with MAINBUTTON
8. Run LSXVOID_DEFAULT_SETUP.exe
9. Check that all values have been restored
run road runner and make sure everything is the way it should be.
note if you have customized the button layout in the skin, this will reset it to the default layout, so back up your original rr.ini file before you run these test.
Thank you.
Both tests worked on my system
