Page 106 of 131 FirstFirst ... 65696979899100101102103104105106107108109110111112113114115116 ... LastLast
Results 1,051 to 1,060 of 1303
Thread: LSX (VOID) released
  1. #1051
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Quote Originally Posted by liquid_smoke View Post
    click and hold on the playlist button in the audio player, an OSK will pop up for you to name and save the current playlist.
    Ok so I had that correctly done but how do you pick the saved playlists?
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  2. #1052
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    lost reception. thank you .. that solved the issue.
    LS. thanks for looking into this and verifying this also.. I noticed ather changes in the rrconfig screen, but i missed that one. Thank you both.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
  3. #1053
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by Civic03 View Post
    there will be a new method in the next release, but currently this is how its done.
    1. you want to create a folder inside of your music lib to store your playlist.
    name it something that will force it to be on the top of the list. In my setup this folder is named
    "-{saved list}-" without quotes. The dashes keep it at the top.
    2. Set your Playlist Path in RRConfig.exe to this folder
    When you are in the audio browser just go into this folder and you'll see all of your saved playlist and can load them just as you would other media.
    In the next update there will be a button that will popup a screen with a list of all your saved playlist.
    beer replenishment fund
    mp3car live search
  4. #1054
    Dec 2005
    Thanks LS.
    My Carputer Blog
    Car System Site
  5. #1055
    Apr 2006
    Chicago
    hey LS. i know we discussed this before. but i know your working on another update and i didnt see this listed on things to do yet.
    audio controls in the webbrowser screen. volume+/- next prev and pause/play.
    i thought you were going to add them before, and then things got switched to the browser plugin. just curious if your still going to implement this. Y
    My Worklog
  6. #1056
    Aug 2003
    Chicago
    Quote Originally Posted by yrean View Post
    they are implemented, next prev and pause/play are there, no volume buttons though. The skin only supports the new webbrowser plugin and the audio controls are only available if your using the plugin.
    When you click the Fav button it will reveal the audio controls.
    If you were expecting the audio controls to be in the same area as on other screens etc, this likely will not happen as it would take too much screen space from the browser window.
    mp3car live search
  7. #1057
    May 2006
    Houston
    RadioShark
    I am having problems getting RadioShark to run native. I have followed the instructions here:
    RadioSHARK v1 is now native to RR.
    and I have changed the I have replaced the radio_player.skin with the radioshark_player.skin and copied over the needed jpgs (the ones that come with radioshark that appear to have been designed for LSV). When I click on FM it goes to the proper skin but radioshark never launches or runs. Is this a RR problem of skin problem? Do I need to change something the Exectbl.ini file too?
    Thanks for the help.
    -GK
  8. #1058
    Aug 2003
    Chicago
    Quote Originally Posted by Gurukarma View Post
    -GK
    I dont use radioshark, or any pc based radio at all, but looking at the instructions from the link you posted , you didnt follow the steps correctly.
    It says you dont need any special radio player skin,(should work with no edits to the skin) so you prob shouldn't have copied over the one included with the skin. It also says it works with radio_player.skin and dosent mention radioshark_player.skin that you got from somewhere else.
    There are no special radio commands in the ExecTBL.ini or in the skin, everything about the radio is pure standard so any issues you may have is likely a configuration problem either in RRConfig or with radioshark.
    It also says you have to patch RadioShark too.
    mp3car live search
  9. #1059
    Aug 2003
    Chicago
    Testers Needed
    i have a utility i made that will basicly setup the rr.ini settings for this skin automatically when you install the skin and any time after if you want to reset to defaults.
    I need some people to test it though to make sure it does what it says on the box.
    1. Backup your RR.ini file in the root of RoadRunner install
    2. download and uzip the attatched file into the root of your RR install dir
    3.Open RR.ini and scroll to the bottom till you see lines about 30lines that start with "MAINBUTTON1="
    TEST 1
    4. Randomly remove values after the equal sign
    5.Save the file and run LSXVOID_DEFAULT_SETUP.exe
    6. Open RR.ini and check that any values you deleted are now restored
    notes: to delete the value make sure it looks like this
    original: MAINBUTTON1=0
    deleted value: MAINBUTTON1=
    TEST 2
    7. Open RR.ini and remove all lines that start with MAINBUTTON
    8. Run LSXVOID_DEFAULT_SETUP.exe
    9. Check that all values have been restored
    run road runner and make sure everything is the way it should be.
    note if you have customized the button layout in the skin, this will reset it to the default layout, so back up your original rr.ini file before you run these test.
    Thank you.
    Attached Files Attached Files
    mp3car live search
  10. #1060
    May 2004
    Both tests worked on my system
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
