Page 11 of 131 FirstFirst ... 2345678910111213141516171819202161111 ... LastLast
Results 101 to 110 of 1303
Thread: LSX (VOID) released
  1. #101
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Well everything is still good on the carPC but i was testing the new LSTOOLS and everything works ok except I got an error message when trying to exit fullscreen. I am posting the attachment so you can see whats going on. Seems it cant find a file or something? I double checked all my paths and everything seems ok. Just wondering how come you decided to use scripts to close fullscreen menus? The other skins I use with fullscreen GPS functions it seems to be hard coded into the skin. It's probably because ive done so much configuring and testing on this laptop that things have gotten corrupted. I may try a clean install of everything. Havent had time to try out the Xport yet (wife was horny, hint hint) but hopefully i'll be tackling that one tomorrow.
  2. #102
    May 2005
    Vienna, VA
    blk, I see that you have a non-standard installation location for RR. Did you use the Install Shield or did you install RR manually?
    Also, what version of RR do you use?
    This might fix it but it's just temporary until liquid_smokes comes out with a new release. Create a folder like this.
    C:\Program Files\Road Runner\
    Then in E:\Road Runner\ you should see a file called exec.exe. Copy it over to C:\Program Files\Road Runner\.
  3. #103
    Jul 2005
    Motorcity
    Blog Entries
    1
    b8bboi, it worked! I thought it may be someting with the paths. On the car pc i have the standard instal path which probably explains why everything works nice
  4. #104
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    yes, everything is done with the assumtion that rr is installed in the standard path. Ive actually worked around any of those issues and this new file exec.exe that is in the root of RR kind of breaks it when i point to it. Im not sure if that file HAS to be located in the root of RR,(its existance is new to me) if not ill prob make a copy of it inside LSTOOS which my skin can find no matter what dir RR is installed in.
    beer replenishment fund
    mp3car live search
  5. #105
    Aug 2003
    Chicago
    Quote Originally Posted by blk02si
    Just wondering how come you decided to use scripts to close fullscreen menus? The other skins I use with fullscreen GPS functions it seems to be hard coded into the skin...
    i dont think any of the other skins have "true" fullscreen gps where the map covers 100% of the screen. They usually have a area that is still apart of RR with a standard RR button. The fullscreen gps screen has NO rr buttons or controls at all, thus i had to create my own button that sits ontop of the map.
    mp3car live search
  6. #106
    Aug 2003
    Chicago
    OK, another update to LSTOOLS, and hopefully the last one. This should resolve any issues anyone who had issues previously.
    mp3car live search
  7. #107
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    The new tools work fine for me now.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  8. #108
    Aug 2003
    Chicago
    Quote Originally Posted by Quattro
    cool, thats what i want to hear
    mp3car live search
  9. #109
    Dec 2003
    New York
    the only thing I had to change was coords.ini so the menu would noy cover up the close button.
    15
    300
    15
    245
    Installed
  10. #110
    Aug 2003
    Chicago
    15
    300
    15
    245
    it will only cover the close button if the skin res is set to 800x480 (desktop testing), but in teh car you more likely have it set to 800x600 in which case it wont cover the close button.
    mp3car live search
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
