Thread: LSX (VOID) released
  1. #1091
    FLAC djmickyg's Avatar
    Feb 2004
    hey LS i just tried out the
    LSXVOID_DEFAULT_SETUP.exe
    and it works real good...
    did u ever get the FREEDRIVE skin files from dbassix??
  2. #1092
    Saturated_Fat's Avatar
    Dec 2005
    Rockville, MD
    err.. I soo screwed something up. I havnt been keeping up with with mp3car stuff and suddenly I see a 1.6patch for void... so I apply the patch...everything works fine EXCEPT on my XM screen the GPS info is unreadable for direction and the speed is in negative numbers....
    Do I just need to apply 1.6 then the patch to fix this? or is it something else.
    Thanks~!
    Shotgun! - An Advanced CarPC Software Solution!
  3. #1093
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by Saturated_Fat View Post
    Thanks~!
    yes you first have to install 1.6 then install 1.6patch
    if you apply the 1.6patch to the 1.5 version only about 10% of your files got updated.
    beer replenishment fund
    mp3car live search
  4. #1094
    Aug 2003
    Chicago
    Quote Originally Posted by TxAxZxZ View Post
    LS,
    I feel your pain. I've been through 4 hurricanes (living in hurricane alley and all). I've been pretty lucky though...no scratches yet.
    Hope everything is ok there.
    yeah, damage isnt bad at all as far as the (my) actual house is concerned.
    No power going on day 3 now though, and im stuck at my moms house.
    mp3car live search
  5. #1095
    Aug 2003
    Chicago
    Quote Originally Posted by CTS_V View Post
    I've tried to get this working in Void since 1.6patch1 was released and I'm outta ideas.
    Using Xport3
    RR Beta 09/12/06
    IG3.0
    LSX_Void 1.6patch1
    Full XP install
    -gps on com4
    -xport splitting to 5 and 6
    -RR uses 6, and speedo and heading work in void
    -IG uses 5 works perfect (using ig native, awsome work, you guys amaze me)
    -Everything except the tripmeter plugin works
    Trip/Milage symptoms
    -heading, altitude, and whatever else in on the bottom row works, so its reading from the GPS.
    -current speed - DOES NOT show
    -no reaction to any buttons except gas which brings up the calc
    -calc has no reaction to any input except when i hit enter and the calc display shows 'c/'
    I did regsvr32 the milage.dll, rebooted, reinstalled 1.6 and the patch. I'm stuck, any ideas?
    Thanks...
    ill have to take a look at the trip meter stuff, its the only plugin i didnt test in the car.
    The dll for the plugin gets automatically registered though when you install lsxvoid. Not sure if that may be an issue if you re register the dll, shouldnt though.
    mp3car live search
  6. #1096
    Aug 2003
    Chicago
    Quote Originally Posted by CARLOS_CET View Post
    I've done a search on this and read post after post. I have IG3 and don't need the extra set of menu buttons (the big arrow on the left with menu options). I have read that i set ignative=true in rr.ini but that didn't help.
    I also have a problem where part of the screen on the left is cut off so where it supposed to read ETA..I only see half of the T and the A. Please help and I did do a search so but it seems like I can't find a straigh answer on how to disable that extra menu, igcontrol? Thanks.
    to fix the issue with part of IG screen on left is cut off you need to download the latest beta version of RR, it fixes this.
    You are prob the first person to ever ask how to disable igcontrol, so thats why your search turned up no results. The options in that flyout menu are designed for IG3 and without it they are harder (more clicks) to get to.
    If you look inside the LSTOOLS folder you will see a modded iGuidanceUMPC.exe file. Not sure if you are using it, but if you are, you may want to keep igcontrol.
    but to disable igcontrol from running, open ExecTBL.ini found inside the skins folder. Find and edit these 2 lines.
    igcontrol enabled: default
    Code:
    /IG3 NATIVE
    "GPSFS","LOAD;external_gps_full.skin;RUN;;iGuidance||RUNQ;LSTOOLS\SB2.9_IG3\iGuidance\EXIT_FS.exe||RUN;LSTOOLS\SB2.9_IG3\iGuidance\IGCONTROL_FS.exe"
    "GPS3","GPS||RUNQ;LSTOOLS\SB2.9_IG3\iGuidance\IGCONTROL.exe"
    igcontrol disabled:
    Code:
    /IG3 NATIVE
    "GPSFS","LOAD;external_gps_full.skin;RUN;;iGuidance"
    "GPS3","GPS"
    mp3car live search
  7. #1097
    Aug 2003
    Chicago
    Quote Originally Posted by djmickyg View Post
    he never actually sent me a skin for FD, what he sent was .skin files to embed FD. I sent him a message about it a long time ago but he never replied.
    im going to do a FD skin from scratch though, shouldnt take long, ill see if this is something i can squeeze into the update.
    There is a lot of stuff going into the next update, some new features not yet listed on the first post status.
    mp3car live search
  8. #1098
    Oct 2004
    Toronto
    Quote Originally Posted by liquid_smoke View Post
    Thanks for looking at it, I appreciate it.
  9. #1099
    Dec 2005
    LSX-
    So i have been away for a bit, but i am ready to buy some more beer. I have never really got the hang of working with buttons. I would like to get the following parts of rr(current)/lsx void(current) working properly:
    1) IGuidance 3.0 NA-
    Currently, i believe i have native mode running. But it appears that the screen is shifted 1/4 inch to the right. I have a black bar where the image should be. Is there any way to shift left?
    I also hate the menu button, how can i properly remove this item?
    2) AVS window -
    I have read the postings in here as much as i could, but the thread is getting extremly long. My AVS window does not look like it is placed properly onto the screen. I have a 800x600 touchscreen, how do i adjust this setting?
    3) Buttons -
    I would like to change the freeXX buttons to load certain screen files or exe files. I have never been able to find a guide for doing so. Could someone please post a guide for hacking the ini file?
    Thanks for any help on these issues, as i am sure others are having some of the same problems.
    sideone
  10. #1100
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    Code:
    /IG3 NATIVE
    igcontrol disabled:
    Code:
    /IG3 NATIVE
    "GPS3","GPS"
    Thanks. I tried the edits to disable igcontrol and it worked. Nothing wrong with igcontrol, I just like the clean look of not having it there. I thought I was gonna get flamed for not doing a search on this one but I couldn't find anything.
    Looks like I'll have to get the beta version of RR to fix the screen cutoff. I assumed that it was because of igcontrol because when IG3 is opening, it's fine but when igcontrol is displayed, that's when the screen cuts off. Anyway, thanks for the help. I really appreciate it. Can wait for the day skin and mobile emulator.
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 05:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 10:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 03:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 08:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 09:47 AM
