Originally Posted by
liquid_smoke
humm, just a shot in the dark.
The NAVI button can be customized, if you click and hold it a menu will pop up with a list of commands. On the first screen you will see a GPS command that actually is setup for IG3, on the other screens there are buttons for IG2, mapmonkey and freedrive. Just to make sure you are using the correct gps button. Click and hold the NAVI button and choose the first gps button on the first screen.
Also, if have another skin to test with, load that skin up and see if iGuidance embeds into that skin.
Also, if you have edited the ExecTBL.ini file that is located inside of the LSXVOID skins folder, post that too. If you havnt touched it no need to post it.
