Thread: LSX (VOID) released
  1. #1191
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    yeah.. I dont have a LOT of things set up (mainly because I dont know how or because i dont have sat/radio/phone settings to set up) as I just reinstalled my whole OS...
    anyway, I'll try adding those things you said into the ini...
    I'm also using the latest version of RR
    -Emo
  2. #1192
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    ok update...
    I fixed the window name thanks to tmar89, and I added the line ignative=True into RR.ini.... that did not do anything.
    but I noticed that my full screen problem was that the actual iG program was in Full screen mode so I just pressed F and it returned back to original screen.
    now the problem is that it still wont "embed" into the skin. all I see is the NAVI screen in RR and a small IG window that will not move or re size.
    I'm getting close but there's something that I cannot figure out
  3. #1193
    Sep 2006
    Richmond, Tx: USA
    tried the skin today......its looks great but is waaaaaaaaaaay too complicated. Maybe you should provide a manual with screen shots so that we know what button does what
    Also, on some screens I saw buttons with labels like "AABB". Whats that ?
  4. #1194
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    humm, just a shot in the dark.
    The NAVI button can be customized, if you click and hold it a menu will pop up with a list of commands. On the first screen you will see a GPS command that actually is setup for IG3, on the other screens there are buttons for IG2, mapmonkey and freedrive. Just to make sure you are using the correct gps button. Click and hold the NAVI button and choose the first gps button on the first screen.
    Also, if have another skin to test with, load that skin up and see if iGuidance embeds into that skin.
    Also, if you have edited the ExecTBL.ini file that is located inside of the LSXVOID skins folder, post that too. If you havnt touched it no need to post it.
    beer replenishment fund
    mp3car live search
  5. #1195
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    Quote Originally Posted by liquid_smoke View Post
    I dont know if it's my touch screen acting up or whatever but when I press and hold NAVI, it doesnt show any menus..
    I haven not edited the ExecTBL.ini
    I did try another skin (mazda 6 one) and when I press GPS, nothing happens
    I'm just out of ideas here... :/
  6. #1196
    Aug 2003
    Chicago
    Quote Originally Posted by ajamils View Post
    what screen did you see this on?
    Whats so complicated?
    if you install the skin correctly it shouldn't be complicated at all, there is a very minimal use of icons and everything is in plain English. Every button does what it says on the box. AUDIO means audio, VIDEO means video. This is the very reason why i choose not to use any icons to represent functions.
    mp3car live search
  7. #1197
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    I have that AABB button too but I thought it was short for something lol
    anyway, it's on the very right top of the AUDIO menu...
  8. #1198
    Aug 2003
    Chicago
    Quote Originally Posted by Emo View Post
    i doubt its your touchscreen. The only reason click&hold wouldn't work is if your version of RR isnt up to date. I know you said earlier you were using the latest version, but if you can, can you tell me the exact version date for your copy(the date thats displayed when RR is loading). People have told me in the past they had the latest only to find out after hours of debugging that it was a 4month old version. Not that i don't believe you, just want to make sure.
    mazda 6 may be setup to use some other gps, i dont know but the default skin BMV2 is what you should use to test against. This skin is maintained by guino.
    also if you can turn on debugging in RRConfig.exe , if its already turned on, delete the debug.txt file in the root of RR. Start RR up with the lsxvoid skin.
    Click&Hold the audio button
    click the NAVI button
    exit out of RR and send me the debug.txt file
    mp3car live search
  9. #1199
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    Thanks! I'll try that..
    I'll give you the info as soon as possible..
    by the way, where is the patch for VOID? I was reading the FAQ on the first page because since I installed VOID, the EXIT button hangs like you said it would but I can't seem to fix it so I'm guessing I need to patch it
    Thanks!
  10. #1200
    Aug 2003
    Chicago
    that may be your problem
    1.6 patch is also on the first page.
    1.6 full version release is on 9/14 entry
    the patch is on the 9/16 entry
    mp3car live search
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 05:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 10:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 03:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 08:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 09:47 AM
