Originally Posted by
ckny
The other problem is that I don't seem to be able to click through. If I click something under the visual it expans the visual to full screen mode and/or brings up the avs editor.
What should my settings be on the spectrum plugin in avs editor? Should I enable alpha transparency and how much? What about
overlay? This seems like one of the last configurations I'll need help with.
Great skin LS, thanks alot for it. I anxiously await your day version as I can hardly see this one in my setup haha. Looks amazing at night though.
for the transparency, dont set it in the winamp visu config stuff. Dont turn on overlay either.
Open RR.ini and add this line
AvsTransparent=TRUE
Then create (or edit if already present) a file in the ROOT of your RR install named "screensaver.ini" The name is a tad misleading.
The contents of the file should look like this.
Code:
AvsTransparent=True
FadeOnIdle=False
SecondsToFade=300
FadeInterval=10
DefaultOpacity=70
MaxOpacity=255
This will enable transparency for the visuals and also enable click through so when the visuals are on you can still click the buttons underneath.
