Page 13 of 131 FirstFirst ... 3456789101112131415161718192021222363113 ... LastLast
Results 121 to 130 of 1303
Thread: LSX (VOID) released
  1. #121
    May 2005
    Vienna, VA
    It wouldn't be too hard to skin iGMon. Since LSX Void already has those on-screen buttons, just disable the buttons in iGMon (open OnScreenButtons.ini and comment them all out). You might want to make one for AutoZoom though.
    Then just skin the OSK and that should do it.
  2. #122
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by Civic03
    LS, I'm using the LSTOOLS from yesterday and the only problems I saw today was that when I went into GPS mode, the map didn't embed properly into the skin at first. I have to exit out of the GPS mode, come back in and then it would snap into the skin correctly. Did anyone else have this problem?
    I have this problem too, I thought it was just my setup, messing something up.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  3. #123
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    LS what does the new LSTOOLS fix?
    a few things, mainly the issues around the exit_fs tool, i also changed the image for it to fit in with everything else so it dosent stick out. Hightly recommened to get the latest version.
    beer replenishment fund
    mp3car live search
  4. #124
    Aug 2003
    Chicago
    LS it looks like IGMon is working with SkinBedder, does this mean that you'll be able to skin it and fit it into LSX VOID?
    already working on it.
    just came back from a test drive so there are a few things i need to tweak, nothing major, mostly screen switching and sort through all the commands and see which ones make the most since etc. Its gonna be sweet though, im pretty excited about the igmon almost everything works good and are features ive been dieing for in IG for a LONG time.
    mp3car live search
  5. #125
    Aug 2003
    Chicago
    Quote Originally Posted by Quattro
    what version of the lstools do you have now?
    when the map dosent embed properly the first time this is almost allways a timeing issue with IG taking to long or something slowing it down. On your desktop, and if you dont have a gps device and get the no gps error this will happen pretty much everytime. In the car it shouldnt be a problem at all.
    So are you having this in the car or on the desktop?
    mp3car live search
  6. #126
    Dec 2003
    New York
    The latest lstools. Happening on my desktop, still playing around with the skin.
    I waiting for igmon and your skin intergration before I put it in the car, hopefully soon.
    Installed
  7. #127
    Aug 2003
    Chicago
    ah, you shouldnt have any issues in the car then. Ill have an update tomorrow with igmon intergration Driveing to the airport so ill get a good test drive out of everything
    mp3car live search
  8. #128
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    LS, mine is happening in the car. I'll try again today and make sure I'm in a location that the GPS is picking up connection though. But it happened while I was driving and I am almost certain I had a signal.
    CAN'T WAIT FOR YOUR IGMON mod.... Whoooo Hooooo!!
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  9. #129
    Aug 2003
    Chicago
    Civic it dosent matter if you have a signal or not. Only if you have a gps device connected and recognized. Try to run skinbedder standalone outside of RR, does it embed properly? How fast is your machine?
    For reference the list of actions that happen when you click the GPS button the first time:
    load external_gps.skin >launch skinbedder> launch runcheck.exe
    when skinbedder.exe launches it runs startup.exe (found in the skinbedder dir)
    startup.exe is what actually launches iGuidance, and also launches runcheck.exe
    the purpose of runcheck is to loadup igcontrol, its soul purpose is to check if igcontrol is allready running.
    If its allready running it dose nothing and exits, its its not running it will launch it. Anytime igcontrol is launched, its launched from runcheck.exe
    without runcheck, you would get multiple copies of igcontrol running.
    It may sound like a lot, but these actions are executed pretty fast.
    I dont belive its RR thats not embeding properly, but skinbedder. Think of IG as a photo thats behind 2 picture frames.
    In my experience ive found the embed issue only happens to me on the desktop where i dont have the gps device and get the popup warning about no gps device detected. Which puts a pause in the string of events that happen and creates a timing issue. If you've been using skinbedder since it was created you likely are already famaily with this issue.
    also, FYI im no way locked into using skinbedder, basicly the only reason i use it is cuz its the only app that will remove the filemenu from IG, all the other apps that say they do this never ever worked for me or were bloated with extra features and clumbsy configs. If anyone knows of a better solution, Im all ears. In a perfect world RR would embed iGuidance and remove the title bar on its own, that way we wouldnt have to use a boatload of external tools to accomplish this task.
    the above is just a little insight for those that may or maynot know whats going on in the background when you launch GPS.
    mp3car live search
  10. #130
    May 2005
    Vienna, VA
    liquid_smoke, you can use _Singleton to make sure your app only runs once. Something like this.
    Code:
    if _Singleton("iGControlRunning",1) = 0 Then
        Exit
    EndIf
    BTW, if you need help skinning iGMon, let me know.
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
