Originally Posted by
aducrejr
LS,
I have everything working fine except when using GPS, IG covers up the top buttons. (menu,go?,cancel Rt. 2d/3d, route list) I didnt notice I was having this issue unti I was drving and couldn't cancel route.
this is by design. Those buttons do work though, i just chose to cover them up instead of remove them completely incase anyone wanted to use them.
If you are using igmon (which you should its awesome) then you can install the igmon skin i did (check updates post 2nd or 3rdpost) and you will have access to cancel RT etc. Also, there is the igcontrol script, (red menu button) that has some options in there also.
In the future updates this feature will be more easily accessed, i ran into the same problem a while ago
But.... if you still want to just use those buttons on the top and dont mind the map area being smaller you can just resize the area where IG will be embeded. Open External_GPS.skin in either RRSKineditor or notepad.
At the very bottom of the file (2nd to last line) there should be a line that starts with A01
change the line so it looks like this
Code:
/, A, x, y, w, h, color;RGB
A01,0,115,800,251,000
