Page 33 of 131 FirstFirst ... 23242526272829303132333435363738394041424383 ... LastLast
Results 321 to 330 of 1303
Thread: LSX (VOID) released
  1. #321
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    i wouldnt bother too much with backing up lstools, i dont make drastic changes to those files, mostly adding new files, or fixing a bug here or there, i dont keep back ups of them myself so unless someone else does?
    If anything ever goes wrong useing an old version of lstools will likely make any issues you had worse.
    beer replenishment fund
    mp3car live search
  2. #322
    Sep 2005
    "Damn the torpedoes - full speed ahead" !
  3. #323
    Aug 2003
    Chicago
    lol
    mp3car live search
  4. #324
    Aug 2003
    Chicago
    oh, i forgot to mention some of the hidden buttons on the main screen.
    1. If you click where the track info/ bitrate etc is located it will activate the ATT function
    2. If you click to the left(of volume down) and right (volume up) of the volume buttons, directly ontop of the numbers this will change the vis to the next one in the cycle.
    clicking album art is disabled and rob wont be turn back on. In the playlist editor this still works though temporarily.
    there arent any other hidden buttons in the skin.
    mp3car live search
  5. #325
    Saturated_Fat's Avatar
    Dec 2005
    Rockville, MD
    Quote Originally Posted by liquid_smoke
    there arent any other hidden buttons in the skin .
    That sounds suspicious....
    Shotgun! - An Advanced CarPC Software Solution!
  6. #326
    Aug 2003
    Chicago
    lol, i wouldnt spend too much time clicking in empty spaces though. You may find something. Nothing big though.
    mp3car live search
  7. #327
    Sep 2005
    LS,
    where is the button for TV and MSG. I notice that there in the exectbl
  8. #328
    Aug 2003
    Chicago
    TV is used for the CAMERA button
    and MSG currently does not have a button associated with it. In the future it will point to some type of instant message app or voip or both. Still unfortunately in the process of evaluateing the current available options for instant messages and voip. Voip holding greater weight as far as priority goes. If you look in Main Menu>RightArrow>Ext Apps>Skype you'll see early skype intergration. I was going to include portable skype in the LSTOOLS but I have to start trying to keep that folder from growing in size too much.
    If you install skype to default path it will work with the skin. Right now it just embeds it.
    mp3car live search
  9. #329
    Dec 2005
    iguidance 3.0
    LS -
    i was looking through exectbl and the lstools folders to integrate iguidance 3.0 into LSX void, however, i havent been able to get it working. Any suggestions?
    thanks man!
    s1
  10. #330
    Aug 2003
    Chicago
    Quote Originally Posted by sideone
    LS -
    thanks man!
    s1
    i dont have IG3 yet, just found out the other day it was even out. But it should be the same setup as anything else really.
    I really need a little more info on your setup and exactly whats not working, and how and where you have IG3 installed.
    The NAVI button uses the "GPS" command.
    The first few sections of ExecTBL.ini are all gps related commands.
    If you see a forward slash / that means the line is disabled by default.
    The two lines you want to look at are
    GPS
    GPSFS
    These options shouldnt even need to be edited though, and likely your problem is either IG is installed to a non default path or the .exe is nolonger named iGuidance.exe. I dont know as i dont have IG3.
    what have you tried to do so far?
    mp3car live search
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 05:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 10:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 03:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 08:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 09:47 AM
