Page 34 of 131 FirstFirst ... 24252627282930313233343536373839404142434484 ... LastLast
Results 331 to 340 of 1303
Thread: LSX (VOID) released
  1. #331
    Dec 2005
    ls-
    i just get a white screen with a crossbar for a mouse icon.
    3.0 has an option for carpc, ppc, or laptops. I have chosen carpc, and the filename was different. It was iguidanceumpc.exe . I have copied it to iguidance.exe. the directory remained the same at:
    C:\Program Files\iNav\iGuidance
    The install was a bit altered, as i dont have a dvd in my setup. i installed ig3.0 onto a pc to cut the maps. then copied to a thumbdrive, then i placed the mapfile to C:\iNav iGuidance which installed a map/ dir beneath the tree. I then installed the ig3.0 app. I have tested it outside of rr, and it runs fine.
    clipped from exectbl (inside the lsx skin dir):
    /--------NO SKINBEDDER ___configure the 2 lines below only if you want to use iguidance without skinbedder or igmod
    /"GPS","LOAD;EXTERNAL_GPS.skin;RUN;C:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance"
    /"GPSFS","LOAD;EXTERNAL_GPS_FS3.skin;RUN;C:\Pro gram Files\iNav\iGuidance\iGuidance.exe;iGuidance||RUN; LSTOOLS\SCRIPTS\EXIT_FS.exe"
    /path to GPS............................................... .......{ path to your gps application }{ window title}
    "GPS","LOAD;EXTERNAL_GPS.skin;RUN;LSTOOLS\SB2.9\SK INbedder.exe;SKINbedder||RUN;LSTOOLS\SB2.9\iGuidan ce\IGCONTROL.exe"
    /....................-path to GPS and EXITFS utility..........{ path to your gps application }{window title}
    "GPSFS","LOAD;EXTERNAL_GPS_FS.skin;RUN;LSTOOLS\SB2 .9\SKINbedder.exe;SKINbedder||RUN;LSTOOLS\SCRIPTS\ EXIT_FS.exe"
    this command is used only on External_GPS.skin, close button on bottom left
    "EXIT2","RUN;LSTOOLS\SB2.9\iGuidance\kill.exe||EXI T"
    "LASTSCR2","RUN;LSTOOLS\SB2.9\iGuidance\kill.exe|| LASTSCR"
    thanks,
    s1
  2. #332
    Dec 2005
    ls -
    also, i just noticed that the [menu] overlay is present, igmod i believe. I dont know if this interferes with 3.0?
    s1
  3. #333
    Sep 2005
    Quote Originally Posted by sideone
    ls -
    s1
    Just for clairification. The menu that one sees that is an overlay of the main GPS screen when iGuidance is embedded within RoadRunner and LSX Void is not produced by iGmod. I do not have iGmod installed and am running version 2.13 NA of iGuidance and the menu is present and very functional!
    Perhaps the Window Title has changed in the latest version of IGuidance? Really just a guess on my part, but wouldnt that account for the symptom that is being experienced? Have you used one of those snooper programs to determine the window name of the Iguidance 3.0 window once its launched?
  4. #334
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    well it looks like a few things are changed.
    the install path
    name of .exe
    and the window title prob has changed also for the umpc version
    what i will need from you is the proper default information for all these items.
    to get the window title run the file i have attatched, this is a window id tool that comes with autoit.
    Attached Files Attached Files
    beer replenishment fund
    mp3car live search
  5. #335
    Aug 2003
    Chicago
    GPS SETUP:
    here are some screenshots of how i have gps setup, if yours isnt setup like this, you will likely have issues. I have highlighted and pointed to areas that will cause issues if the values arent the same on your box.
    Hope this helps.
    mp3car live search
  6. #336
    Dec 2005
    ls -
    well just like everything else on windows, i guess i needed a reboot. After i rebooted, everything worked correctly. So.. the only change i needed to make for 3.0 was changing the filename to match iguidance.exe ..
    Sorry to waste your time.
    S1
  7. #337
    Aug 2003
    Chicago
    odd that a reboot fixed it, im curious though if you renamed it? wasnt there already an iguidance.exe present? or is it located in a different dir.
    glad u got it squared away though.
    Can you tell me if the menu button that pops up when you go to the gps screen, does this still work with IG3? I hear they removed keyboard shortcuts from the application (cant think of any good reason to do this to any app). Also if you use igmon does it still work with the new IG version?
    thanks
    mp3car live search
  8. #338
    Variable Bitrate kiztope's Avatar
    Nov 2002
    In the car
    Ls, kinda off base, but what are you using to skin windows? (or is it Vista?)
  9. #339
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    Hey Smoke, You were missed at the meet bro, I had to drink all that beer by myself. lol.. j/k. i had a few but i dont drink and drive. I was sober when we left, but it was a very good time. maybe next month.
    What I was going to ask about. Is I want to make an LSX_Void Day skin. The black of the smoke doesnt do any justice in the daylight. What I was thinking of doing was, just taking the skin into PS, and iverting, so black would be white, white would be black. then id have to edit the skin to change the font colors from whit to black etc. I love the skin, but the darkness in the day loses the beauty of it. You feel like making up a day skin real quick like that, or any way I could get the PS files. would be much easer to invert the colors by layer. oh well. thanks much.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
  10. #340
    Aug 2005
    San Francisco
    Any reason why I would have a $NEXTTURN$ appearing under the Audio button?
    This is with. WinAmp 5.1 Newest LSXVOID, LSTOOLS, RR and IGuidance 2.1 + Skinbedder from LSTOOLS
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 05:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 10:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 03:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 08:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 09:47 AM
