glad u got it working.Quote:
Originally Posted by Meneerdeman
Printable View
Ok I want this to be done when I click on navi. When I click on navi it open up copolit by itself and does not jump to the GPS screen. Can this be done. RR will still be in the background but copliot load on top of it and I use the alt tabber to switch back and forth
yes you can do this, you just have to edit what the button does. I do not have copilot so i cant configure it for you.Quote:
Originally Posted by tn6478
All you have to do it edit the ExecTBL.ini file and edit the "GPS" command to open copilot. If you look at the ExecTBL.ini file there are instrucions on how to edit it, also there is a faq on how commands work in RR.
when you click the NAVI button it send the command "GPS" to RR. RR looks iside the ExecTBL.ini file to see what action/s it should do.
if copilot runs fullscreen (i think it does) you will need some way to get back to RRCode:"GPS","RUN;path to copilot/copilot.exe"
I got it to work thanks also how to u update the weather I don't seem to update.
what do u mean by update?Quote:
in RRConfig.exe at the very bottom are weather settings, thats all you need to do.
I don t see anything in the weather screen its always blank.
did you set the weather settings up? your city/country?
Yeah I am located in houston, tx and i set up everything right but never see the weather. I am also online when I do this. Is there another external software for weather that I need to install.
no there is no other software you need, the weather stuff is built into RR. You prob put your zipcode into the settings, which is the first instinct.
It shold look like this
cityweather=Houston,Tx
weatherunits=USA
I didnt put any zip code i have this install on 2 computer for testing and no weather.
