Originally Posted by
tn6478
Ok I want this to be done when I click on navi. When I click on navi it open up copolit by itself and does not jump to the GPS screen. Can this be done. RR will still be in the background but copliot load on top of it and I use the alt tabber to switch back and forth
yes you can do this, you just have to edit what the button does. I do not have copilot so i cant configure it for you.
All you have to do it edit the ExecTBL.ini file and edit the "GPS" command to open copilot. If you look at the ExecTBL.ini file there are instrucions on how to edit it, also there is a faq on how commands work in RR.
when you click the NAVI button it send the command "GPS" to RR. RR looks iside the ExecTBL.ini file to see what action/s it should do.
Code:
"GPS","RUN;path to copilot/copilot.exe"
if copilot runs fullscreen (i think it does) you will need some way to get back to RR
