So how do I congifure LSXVoid to work with Capture!?
I tried adding this line in the ExecTBL but it didn't work:
"CAMERA","RUN;C:\Program Files\Capture!\Capture!.exe"
Printable View
Quote:
Originally Posted by tn6478
can you send or post your RR.ini and also what version of RR are you running.
Quote:
Originally Posted by 65coupei6
the command for the CAMERA buttons is TV. so your code should look like this
"TV","RUN;C:\Program Files\Capture!\Capture!.exe"
also, check to see if there is already a TV command in the ExecTBL.ini file and either edit that command or disable it with a forward slash / infront of the line.
The way your command is now the application will launch but will not embed into RR unless the screen your on is setup for embeding an application, you specify a screen (.skin) that is setup for an application and you specify the window title at the end of your command. Check the ExecTBL file for examples.
also in the future when editing the skins commands, know that there are no standards or rules to what a command can be. It can be anything you want it to be. So allways check the buttons command in RRSkineditor or notepad. The name on the buttons are mostly just that, labels.
also @ [B]tn6478
if your new to RR, another problem may be that weather isnt setup correctly. I cant remember is weather is included with RR when downloaded or as a plugin.
I do remember at some point, when it was first introduced you had to download some extra files. So check to see if you have a Weather folder inside the RR install dir. If you dont have this folder you can grab it here.
http://guino.home.insightbb.com/download.html weather.zip
so i guess its not distributed with the RR download (not sure) so that maybe your issue.
update this weekend,
the main download for the skin will be updated and there will also be a smaller update with only the files that have been added or changed since last update, trying to keep a log of changes now.
whats new:
RR native picviewer support
Radio Player fixes
video player rework
other small fixes.
the update is done, i just need to create a ON state for a new screen thats being added. Kind of lazy right now, so it should be avail today sometime.
humm, i just noticed something i didnt think was enabled.
can someone using the latest version verify for me if when they click the AUDIO button, does it make a click sound?
any Thunderbird users out there? :)
Mozilla Thunderbird? Yes.
yes,
think i may be a new convert. I tried it a long time ago when it was in beta but didnt like it, but now seems to be pretty cool. Think i may slip it in the update.
:whs: also using thunderbird
