any possibilities of adding skin for the rrmobile plugin, that is if I can get it working.
but not sure if it's skinable.
updates ready, check first post
beer replenishment fund
mp3car live search
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Pardon my ignorance, I've never used thunderbird... but, I have 2 questions:
1. Is it just used for Email?
2. Is it skinnable?
its mostly for email, no fluff. It does have a really nice RSS news reader. So far im really likeing it comeing from using Outlook for so many years. The only thing its missing for me is notes and winmobile sync. Still havnt figured out how to get my contacts from outlook and into thunderbird, outlook has really crappy export options.Originally Posted by kiztope
Give it a try, if you dont like it you can allways replace it with something else.
Im gonna expand on the support very soon.
and yes you can use skins for it, same format as firefox. I want to skin it also but so far havnt found any info on exactly how you skin it, or firefox. Has to be somewhere though.
mp3car live search
i havnt been following the rrmobile thing to close, the few times i tried it couldnt get it to work properly. Not really sure what the direction is on that. Maybe i should chime in on that thread. With pretty much all skins (most) having phoco support, it would prob be in his best interest to make his plugin compatible with existing skins. Seems like that would be the easiest way too since the source for how RR looks for information from phoco is available inside RR, seems he would only need to make his app send the same commands to RR and not even deal with adding ui features. But i cant code a lick so what do i know.Originally Posted by Quattro
Im not against adding support for it, but only when its more mature and it has to at least work for me so i can test it while i skin.
mp3car live search
Hey, what visualization is this and how did you get it there?
Originally Posted by StLB5
Read the thread.... it's in here!
Smoke.. gotta question for ya. Im running lsx void obviously and im running igmon. before your update it was working ok. i still wastn able to get rid of the skinbedder menu button, but i would of found it eventually. If you want to tell me how exactly to remove that cool, if not ill figure it out.
the main thing im seeing, is once i updated to the latest version igmon no longer pops up and works. its running in the task bar, but when i access the gps it doesnt work. is there something i need to do to make the new version work with the igmon? thanks. Y
MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
7" Lilliput 619 | WinTV | WIFI | Bluetooth
Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
Roadrunner | LSXvoid | IGuidance 3
My Worklog
Originally Posted by yrean
need just a tad bit more info.
not sure which menu button you are trying to remove.
There is a menu button created by igmon, menu button created by my skin and the default menu button that is apart of iGuidance.
If you are using the latest version of the igmon skin (check 2nd post) the menu button should look like cog and should be present.
The only way to remove the menu button that is apart of iGuidance itself is to use the included iguidance.exe file found inside of LSTOOLS.
I havnt checked if there are newer updates, but the igmon skin is compatable with igmon 2.01
I would not copy the igmon 2.x updates ontop of an igmon 1.x install ( i had issues when i did this) and u should make a fresh igmon 2.x dir install.
mp3car live search
updated the second post with a link to the visualization used in this skin. Thought i linked it in the updates already, but guess not.
mp3car live search
