need just a tad bit more info.
not sure which menu button you are trying to remove.
There is a menu button created by igmon, menu button created by my skin and the default menu button that is apart of
iGuidance.
If you are using the latest version of the igmon skin (check 2nd post) the menu button should look like cog and should be present.
The only way to remove the menu button that is apart of iGuidance itself is to use the included iguidance.exe file found inside of LSTOOLS.
I havnt checked if there are newer updates, but the igmon skin is compatable with igmon 2.01
I would not copy the igmon 2.x updates ontop of an igmon 1.x install ( i had issues when i did this) and u should make a fresh igmon 2.x dir install.
