Originally Posted by spestka
the visuals use the ONSKINSTART command to auto load when RR runs.
To stop it from loading do this.
Load ExecTBL.ini (found inside the skin folder)
scroll to bottom of file and edit the "ONSKINSTART" command
This command does 2 things when RR starts, it starts the visu and also displays the welcome message.
If you want to stop the visuals from autostarting use this line.
If you want the visuals to start but NOT the welcome messageCode:"ONSKINSTART","RUN;LSTOOLS\welcomeMSG\welcome.exe"
If you dont want either to autostart simply put a forward slash at the begin of line.Code:"ONSKINSTART","VISU"
Code:/"ONSKINSTART","VISU||RUN;LSTOOLS\welcomeMSG\welcome.exe"
LinkBack URL
About LinkBacks
