sorry i missed this earlier, i read it but somehow forgot in the process of posting replies.Originally Posted by left_hooked
There is a faq (in the RR faq section) on how to setup the camera support, you have to download a winamp plugin (tv or something like that) and after you follow the setup it should work for you in the skin.
The fonts included with the skin go into the windows font dir, to install fonts you just copy/drag and drop the fonts into the windows font dir
Start>Control Panel> Fonts
skinbedder should never automaticly run when you launch RR. There is nothing in any of the settings that will auto launch it. If you send me a copy of your RR.ini, ExecTBL.ini (in root of RR install and also from inside skin folder) i can take a look and see why its auto starting for you.
as for the calendar, there is a setting in Rainlender to stop it from automaticly opening the upcomeing tasks, etc.
Open the Calendar right click the window> Config>General tab>
uncheck "Show all todays messages at startup"
LinkBack URL
About LinkBacks
skin is still awesome tho
