Page 48 of 131 FirstFirst ... 38394041424344454647484950515253545556575898 ... LastLast
Results 471 to 480 of 1303
Thread: LSX (VOID) released
  1. #471
    Variable Bitrate kiztope's Avatar
    Nov 2002
    In the car
    Quote Originally Posted by theheel
    this may be a stupid question that was asked before.. but i didnt see it while reading through all the posts.
    How do u get the spectral analyser to show up instead of the milkdrop visualization, that i see on a few of the pictures
    i downloaded the spectrum.rar file, but what do i do with it?
    Set your AVS in RRconfig to be AVS, instead of milkdrop.
    Then configure Winamps AVS to be Spectrum...
    You should be good to go!
  2. #472
    Jul 2006
    Quote Originally Posted by kiztope
    Then why is mine not working
  3. #473
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Anyone using IG3 with this?
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  4. #474
    Dec 2005
    Quote Originally Posted by liquid_smoke
    yeah, there used to be a home button, but all it did was open the Favorite Destinations window and navigated to the first entry, thats if you have the first entry set to your home. This can still be done using the fav button instead. There is a home feature in igmon now also, so if i havnt allready (cant remember) ill move that feature there. It asks for the actually log and lat of your home so its a tad bit more to config but nothing crazy.
    The GPS screens constantly are under speculation from me to find that perfect blend of features and useability so things come and go and come again in various updates. Ill prob take some looks at it this week.
    Thanks LS, I actually configured IGMon Home feature already. I thought when you hit the OSD button the Home option was there. Thanks for looking into it.
    I was looking for it last week when I was on travel!
    My Carputer Blog
    Car System Site
  5. #475
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Quote Originally Posted by left_hooked
    I replied via PM, but here is the answer.
    Apparently you need to be running Winamp 5 or greater.
    And you need to put those AVS files into the (in my case)
    c:\Program Files\Winamp\Plugins\avs\Winamp 5 Picks\
    Just look to where your other .avs files are and put it there.
  6. #476
    Nov 2002
    In the car
    Do you have winamp 5?
    Does it work when you press the vis button? (the date in the uppper right?)
    Mine still doesn't work automatically, but it works fine when I press the vis button....
  7. #477
    Jul 2006
    I have version Winamp 5.24. See attached to feel my pain..lol
    Doh, forgot to have the Vis open for print screen, see second attached.
    EDIT: Actually, yes it does. So now we just need to figure out as to why its not auto loading when music starts <after I resize it to the "A" position in the skin.
  8. #478
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by Civic03
    in the process of doing a full IG3 mod as i type. Replaced most of the icons and buttons in the umpc version so far. Ill release it in a seperate thread as it should match pretty much any skin that is dark/black.
    beer replenishment fund
    mp3car live search
  9. #479
    Aug 2003
    Chicago
    winamp version 5.1 is the latest you can/should use with RR.
    any other versions higher and problems start to pop up.
    make sure you have the latest version of RR
    check both of your ExecTBL.ini files, on in the root of RR install and the other in the skins folder. Make sure the one in the skin folder is up to date, (check first post for download).
    also check the faq post (3) it has an entry for the visuals and how to setup/edit/autostart etc.
    oh, also looking at your screen shot,
    set winamp to use CLASSIC SKINS and not modern, thats why its not embeding
    mp3car live search
  10. #480
    Jun 2006
    IG3 mod..
    Anxiously awaiting..... I just cranked up IG3 today too --- man did they solve a lot of the problems we've had to paste around ... Much more CarPC friendly!!!
    I look forward to this in a big way - will it be all of the ResHack stuff and simply the pieces we could change? I don't for immediate like the zoom icons they have - but everything looks so big and would swap so nice....
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
