Page 5 of 131 FirstFirst 12345678910111213141555105 ... LastLast
Results 41 to 50 of 1303
Thread: LSX (VOID) released
  1. #41
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by hoodlum
    How would I cut down the features?
    Fm, XM, Sirrus, SAT, Ext Apps, M MODE, SKIN, CAMERA, DRAW, SKIN, WIDGETS, Calender. And how do i get WEATHER to work for toronto? or canada.
    check the faq post at the begining of this thread.
    you do know, if you remove the SKIN button you will not be able to change to another skin unless you run rrconfig.exe
    also, fyi
    the CAMERA button is broken right now.
    beer replenishment fund
    mp3car live search
  2. #42
    Aug 2003
    Chicago
    Quote Originally Posted by liquid_smoke
    yeah, its pretty old. I think im going to retire it though and roll it into the other utility, that way you only have one button on screen.
    second thought, i dont think im going to do that. Although it would only be one button on the screen, it would turn exiting out of fullscreen mode into a 2click process. So ill prob just change the code and not the position or percieved way it works.
    mp3car live search
  3. #43
    Aug 2003
    Chicago
    and to get weather to work, run RRConfig.exe or click the CONFIG button in the skin.
    at the very bottom of the list is Weather Settings
    mp3car live search
  4. #44
    May 2005
    Vienna, VA
    is that reg key on everyones machine or does it only get written there if you used the install ver of RR?
    I'm not sure. We can ask guino.
    Also, if you want it to be totally transparent, you can send commands directly to RR from AutoIt.
    Need help with sending RR SDK commands from AutoIt
  5. #45
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    LS got a reply for my question?
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  6. #46
    Dec 2005
    LS et All, which Gamacontrol do you guys use? Do you use the GamaControl software or you use what's in the skin?
    My Carputer Blog
    Car System Site
  7. #47
    Nov 2004
    St Louis
    Hey LS, we missed you yesterday. Been playing with this skin a little, but where's the mute button? I use the three way mute function and am lost without it.
  8. #48
    Low Bitrate wishbone's Avatar
    Feb 2006
    DiNASTY or liquid is it possible to get the "point north" button added to that really nice menu you've added for skinbedder/iguidance? I find that I use that more often than I thought.
    Thanks again for all your work with this, seems like a great skin from what I've played with so far!
  9. #49
    Dec 2005
    Patches and Updates
    update 1
    this fixes the online indicator that should have been in the release. external dvd will come in patch2
    Calendar support
    this is a rainlendar skin to match lsx void
    800x600 800x480
    These files go into the skin dir under rainlendar
    C:\Program Files\Rainlendar\Skins
    Does this need to be installed in that directory? Do I need anything other than what's in this zip file?
    My Carputer Blog
    Car System Site
  10. #50
    Saturated_Fat's Avatar
    Dec 2005
    Rockville, MD
    Quote Originally Posted by Civic03
    I used the default paths, installed rainlendar , unzipped the skin . THen loaded rainlander,set the skin,exited. Now run rr and try touse the calender
    someone chime in if thats at all wrong cause im really tired.
    edit: either launch rainlander by itself and move the windows to the desiredlocations (allign with rr). or turn off gestures then allign the windows. This may not be neccessary,but it was when running it on my laptop, not inmy car.
    ok now I'm really gone nyquills a kickin in.
    Shotgun! - An Advanced CarPC Software Solution!
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
