:whs:
also, the most common mistake with winamp and vis is that people have winamp set to use modern skins. Make sure winamp is set to use classic skins.
Printable View
:whs:
i do too :)Quote:
Originally Posted by Civic03
i doubt anyone actually uses that other thing much and this is much more usefull.
not long at all, maybe 15 minutes. Each dialog shares the same background and a lot of elements share the same button graphic. Prob the process that takes the most time is importing back all the modified graphics.Quote:
Originally Posted by DiNASTY
the only top left hidden button i use is on the main screen itself in order to minimize RR to get to the desktop. the menu screen itself your talking about. I never use.
I really have problems with the fonts now. Non of the fonts needed for the skeen seems to work, buttons look all messed up. I've tried to install the fonts for the skin several times into c:\windows\font directory and remove them and installing them again but dosen't work. The install bar for the fonts come up, but no difference. The last time I tried remove and reinstalling them windows told me the fonts was allready installed when I had removed them and tried installing them again.Quote:
Originally Posted by yrean
It's so frustrating ! I got the viz. working but this font thing is driving me nuts! can't understad nobody else has this problem, I have it both on my desktop and carpc now!
font problem solved after 2 more hours with problem searching !:o
Nothing to do with windows. Its RR which tries to cope with windows regional setting, you people in the US won't have this problem probably because you all have the same font settings in windows but here is the answer just check"no internatinoalisation" in RR config !!
Orginally written by Guino:
it allows you to use skins with foreign fonts in the skins (Greek, Hebrew, Russian, Chinese, Japanese etc). Of course the skin must be compatible and the computer must be properly setup for it.. a lot of people have different regional settings (anybody that doesn't use U.S. regional settings) but simply don't know about it.. and that's what causes RR to try and "set" fonts that will work better to display your regional settings.
also figured out that avs visualization embeds correctly with winamp 2.95. With winamp 5.24 the winamp border will show around the milkdrop viz but in right place of the skin, avs will have no border but be in wrong location.
Where can I download the spectrum viz mentioned in this thread? and which winamp ver will it work correctly with ?
Wow this skin is so freakin awesome. Gotta say this skin is being developed at the same speed as the RR binary!!! Hats off to you liquid smoke! I got IG version 3 working with the current LSXvoid but these updates make the IG user interface look much less "fisher price"
Any idea when the IG 3 update will be public?
Wonder what the longest thread on mp3 car is? this has gotta be in the top 5 lol.
@diskey
glad you got the font thing squared away, i guess it makes since since your windows is prob not us english.
I would not go any higher than winamp 5.1x everything else newer has serious issues. The vis is located in the 1-3 post, all downloads are located there and latest is allways located there.
also, for vis make sure you are using classic skins in winamp else the vis windows will not embed. when you use modern skins, the window titles change and thus wont embed.
thanks.Quote:
Originally Posted by blk02si
I try to keep up with guino but its hard!
IG3 update will be soon, 99%of it is done i had to do a lot of scripting (well not really a lot) to make up for some of IG3's shortcomings. As well as change some things in the GPS screen to adapt. There are other things i have to do in other areas of the skin before i release though, i dont want it to be just an IG3 update. I know a few people are waiting on some other things.
Found a few other small issues that i thought i fixed a long time ago.
DAMN this week has flew by!!!! just realised its Thursday now.
so much to do, so little time.
Ill be up pretty late tonite trying to crank out as much as i can, theres some other unrelated things i was supposed to do but didnt.
