Page 53 of 131 FirstFirst ... 3434445464748495051525354555657585960616263103 ... LastLast
Results 521 to 530 of 1303
Thread: LSX (VOID) released
  1. #521
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    also, the most common mistake with winamp and vis is that people have winamp set to use modern skins. Make sure winamp is set to use classic skins.
    beer replenishment fund
    mp3car live search
  2. #522
    Aug 2003
    Chicago
    Quote Originally Posted by Civic03
    LS I think you should replace the old shortcut with this new IG menu.
    i do too
    i doubt anyone actually uses that other thing much and this is much more usefull.
    mp3car live search
  3. #523
    Aug 2003
    Chicago
    Quote Originally Posted by DiNASTY
    Yes... awesome how long it take you to do that screen?
    not long at all, maybe 15 minutes. Each dialog shares the same background and a lot of elements share the same button graphic. Prob the process that takes the most time is importing back all the modified graphics.
    mp3car live search
  4. #524
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    the only top left hidden button i use is on the main screen itself in order to minimize RR to get to the desktop. the menu screen itself your talking about. I never use.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
  5. #525
    Feb 2006
    Quote Originally Posted by yrean
    1. take the font and locate it into the windows/fonts directory. for some reason it doesnt seem your font was installed correctly. make sure you see the font install bar come up. I have thousands of fonts for graphics on my pc, and i remember sometimes a font wont install right. I dont remember why, i just remember it was touchy.
    I really have problems with the fonts now. Non of the fonts needed for the skeen seems to work, buttons look all messed up. I've tried to install the fonts for the skin several times into c:\windows\font directory and remove them and installing them again but dosen't work. The install bar for the fonts come up, but no difference. The last time I tried remove and reinstalling them windows told me the fonts was allready installed when I had removed them and tried installing them again.
    It's so frustrating ! I got the viz. working but this font thing is driving me nuts! can't understad nobody else has this problem, I have it both on my desktop and carpc now!
    BMW 320 CI - 2000 mod.
    Xenarc/Gain 7" TSV with custom dash frame
    Epia M1000 shuttle pc- 80g hd, dvd, holux gps, linksys wireless
    Opus 120W, Trust BT v2 dongle, Wintv card
    Cadenze 500w rms monoblck,
    Cadenze 4ch 400w rms
    Alpine 12" Type R
  6. #526
    Feb 2006
    font problem solved after 2 more hours with problem searching !
    Nothing to do with windows. Its RR which tries to cope with windows regional setting, you people in the US won't have this problem probably because you all have the same font settings in windows but here is the answer just check"no internatinoalisation" in RR config !!
    Orginally written by Guino:
    it allows you to use skins with foreign fonts in the skins (Greek, Hebrew, Russian, Chinese, Japanese etc). Of course the skin must be compatible and the computer must be properly setup for it.. a lot of people have different regional settings (anybody that doesn't use U.S. regional settings) but simply don't know about it.. and that's what causes RR to try and "set" fonts that will work better to display your regional settings.
    Alpine 12" Type R
  7. #527
    Feb 2006
    also figured out that avs visualization embeds correctly with winamp 2.95. With winamp 5.24 the winamp border will show around the milkdrop viz but in right place of the skin, avs will have no border but be in wrong location.
    Where can I download the spectrum viz mentioned in this thread? and which winamp ver will it work correctly with ?
    Alpine 12" Type R
  8. #528
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Wow this skin is so freakin awesome. Gotta say this skin is being developed at the same speed as the RR binary!!! Hats off to you liquid smoke! I got IG version 3 working with the current LSXvoid but these updates make the IG user interface look much less "fisher price"
    Any idea when the IG 3 update will be public?
    Wonder what the longest thread on mp3 car is? this has gotta be in the top 5 lol.
  9. #529
    Aug 2003
    Chicago
    @diskey
    glad you got the font thing squared away, i guess it makes since since your windows is prob not us english.
    I would not go any higher than winamp 5.1x everything else newer has serious issues. The vis is located in the 1-3 post, all downloads are located there and latest is allways located there.
    also, for vis make sure you are using classic skins in winamp else the vis windows will not embed. when you use modern skins, the window titles change and thus wont embed.
    mp3car live search
  10. #530
    Aug 2003
    Chicago
    Quote Originally Posted by blk02si
    thanks.
    I try to keep up with guino but its hard!
    IG3 update will be soon, 99%of it is done i had to do a lot of scripting (well not really a lot) to make up for some of IG3's shortcomings. As well as change some things in the GPS screen to adapt. There are other things i have to do in other areas of the skin before i release though, i dont want it to be just an IG3 update. I know a few people are waiting on some other things.
    Found a few other small issues that i thought i fixed a long time ago.
    DAMN this week has flew by!!!! just realised its Thursday now.
    so much to do, so little time.
    Ill be up pretty late tonite trying to crank out as much as i can, theres some other unrelated things i was supposed to do but didnt.
    mp3car live search
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
