here is the preset,
unzip this anywere you like
run winamp>Options>Preferences>Plugins>General Purpose>Toaster
Configure Selected plugin>Load Preset Point to lsx2.ini
Apply
Apply
ok, toaster is a plugin for winamp
download here
http://www.myplugins.info/toaster.htm
play with that for a while and ill post up my preset later.
Basicly what it does is shows the track info etc when the song changes and fades away, very similar (exactly) to what happens if you were using StreetDeck. But with more options on how it fades in, fades out, slides in, slide out etc etc.
It support keyboard shortcuts so there may be a way to set RR up to only show it at certain times , like on the GPS screen or some other screen that maybe dosent have track info.
Its pretty flexible. I may make a few presets for it release as a pack.
beer replenishment fund
mp3car live search
here is the preset,
Apply
Apply
mp3car live search
ok, i got to install ig3 and your skin today. damn ig3 took alot of time to generate the maps. I also had to comment out/remove the onskinstart command to get it to work.
a couple things though.
1. What do i need to do to make the new draw program work. i click on draw and it goes to a black screen. If i remember youwere adding a really cool new draw app.
2. Ig3 is embeded fine, But i thought you skinned it if i wasnt mistaken. changign colors menu icons etc. to match the skin. what did i miss, what do i have to do to make this work?
MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
7" Lilliput 619 | WinTV | WIFI | Bluetooth
Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
Roadrunner | LSXvoid | IGuidance 3
My Worklog
yrean-
1. you need to download artrage2, you can grab the url from the ExecTLB.ini file in the lsx skin folder, you also might need to make a default painting with a black background.
2. you need to go into LSTOOLS and go to the Ig3 mods folder and copy the two files ctheme.ini and iGuidanceUMPC.exe to the Program Files\iNav\iGuidance folder then you should be all set.
thanks tux11
mp3car live search
LS
You are always thinking sir... love it. I have the Plugin, all working outside of RR just not sure when, how, or if you are using in RR yet. I will work with it a bit myself but curious on your input.
Also - stupid question and plan to search but is the Calendar part of the LSTOOLS load - I dont seem to have it - but will search also.
LS - yes this is SUPER kewl, works great with WinAmp standalone but RR for me simply never shows it..... Curious on what setting I may be missing, and curious how we can control which pages it would show and not show on - but as u state for IG, Games, Gadgets, and many screens dang this is nice.....
should work fine with RR also, should load each time winamp loads.
maybe its loading behind RR, or if you have multiple versions or installs of winamp on your box, its probably not installed in the winamp that RR is using.
I allways have to check this if i install a plugin or something i want to use with RR cuz i have 2 different installs of winamp and it allways wants to default to the version RR dosent use.
other than that i cant really think of any other reason why it would work in winamp but not in RR.
mp3car live search
It wasn't working for me in RR either, but when I had RR running, when and reselected the void skin and it started working. :shrugs shoulders:
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
mp3car live search
