Page 68 of 131 FirstFirst ... 18585960616263646566676869707172737475767778118 ... LastLast
Results 671 to 680 of 1303
Thread: LSX (VOID) released
  1. #671
    Feb 2006
    LS, I now can cofirm mapmonkey works ok. It's so nice to have MM run in the background when in the main menu of the skin, and get the Gaspo warnings.
    BMW 320 CI - 2000 mod.
    Xenarc/Gain 7" TSV with custom dash frame
    Epia M1000 shuttle pc- 80g hd, dvd, holux gps, linksys wireless
    Opus 120W, Trust BT v2 dongle, Wintv card
    Cadenze 500w rms monoblck,
    Cadenze 4ch 400w rms
    Alpine 12" Type R
  2. #672
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Quote Originally Posted by liquid_smoke View Post
    ok, toaster is a plugin for winamp
    download here
    http://www.myplugins.info/toaster.htm
    play with that for a while and ill post up my preset later.
    Basicly what it does is shows the track info etc when the song changes and fades away, very similar (exactly) to what happens if you were using StreetDeck. But with more options on how it fades in, fades out, slides in, slide out etc etc.
    It support keyboard shortcuts so there may be a way to set RR up to only show it at certain times , like on the GPS screen or some other screen that maybe dosent have track info.
    Its pretty flexible. I may make a few presets for it release as a pack.
    Thanks LS as usual!! I got a nail in my tire Monday so I'm not currently driving my car as they need to order my tire because they don't carry it in stock!! I haven't had the chance to play with this yet since I'm not driving my car. I'll get the new skin installed, install the toaster and let you know.
    Thanks buddy... great work.
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  3. #673
    Dec 2005
    here is the preset,
    unzip this anywere you like
    run winamp>Options>Preferences>Plugins>General Purpose>Toaster
    Configure Selected plugin>Load Preset Point to lsx2.ini
    Apply
    Apply
    Thanks...
    My Carputer Blog
    Car System Site
  4. #674
    Jun 2006
    Guys -
    Ok tested everything u mentioned - always good stuff, heck I am at a point if someone tells me to put a nail in my head it may work - I try it ;-)
    Rather than going thru all the other stuff - here is what the skinny appears to be. That Winamp/Plugin works just fine --- does not work in RR when (I have the ShowRes set to 800x600) which I need. So on my test box, laptop native res is 1280x768. When I do a Show of 800x600 in the RR.INI all is stretched, all is good (but this does not display ..... ODD!).
    However - if I use the show at the native skin-res, and there is gap below on my PC (meaning desktop exposed). You can indeed see the Plugin does work and comes in at the proper location as it should, but this res does not do a fill. This may work on my CarPC which is a lesser Res.... but ?
    LS - this was an EXCEPTIONAL FIND!!!!!!!!!! If you guys have some ideas let me know. I am using the SATAN VIS with Winamp and works great with this setting, and thought perhaps there was a confilict - but not.
    Thanks for any input....
    should work fine with RR also, should load each time winamp loads.
    maybe its loading behind RR, or if you have multiple versions or installs of winamp on your box, its probably not installed in the winamp that RR is using.
    I allways have to check this if i install a plugin or something i want to use with RR cuz i have 2 different installs of winamp and it allways wants to default to the version RR dosent use.
    other than that i cant really think of any other reason why it would work in winamp but not in RR.
  5. #675
    Jun 2006
    here is the preset,
    Apply
    Apply
    FYI, on mine, instead of Load Preset, I had to "Import Preset", then point to lsx2.ini. It then asked if I wanted to merge with current preset or create new preset. I guessed at create new and it seems to work.
    That's a cool little feature!
  6. #676
    Jun 2006
    I'm having problems when I open IG3. When I click on Navi, I get a blank white screen for a second or two and then the map will come up without any buttons. I'm running this just on my laptop right now, so when I move the mouse over where the buttons should be, they show up, but the borders are missing. When I go fullscreen and then back to regular, everything is fine. Another problem is that the bottom info section including the speedo is cut off by the bottom buttons (play/pause, fwd, back, etc...). When I exit RR, skinbedder and IG are still running. Any thoughts?
  7. #677
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by StLB5 View Post
    I had to do the samething.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  8. #678
    Feb 2006
    I seriously can't get winamp visual to work with v1.5 of this skin, old version of the skin works good on same computer so it's something in the new skin that's causing it. No visual is showing neither in the main menu or the menu2 full screen visual option. When I click the date in upper right nothing happends.
    seems like the visual window is behind the skin. I tried check/ucheck hide winamp in rrconfig, but the same outfall...
    what can be wrong??
    Alpine 12" Type R
  9. #679
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by diskey View Post
    what can be wrong??
    when you first start the skin up, the visuals should auto start.
    make sure your using classic skins in winamp (im sure you are if it worked before)
    Other than that, ill take a look and see if i can get it to break.
    I was playing with vis stuff befor the release trying to get it to change the size of vis window on the fly, but didnt work out too good, its possible that maybe some of those settings were left behind. I'll double check it.
    There is a small patch comeing soon anyway, so if any fixes are needed in that area it'll be in there.
    beer replenishment fund
    mp3car live search
  10. #680
    Aug 2003
    Chicago
    you likely wont have this problem in the car, ive seen this happen before (rarely) but its just RR not embeding the window properly and repainting the screen. Try it in the car and let me know if you still have that issue.
    mp3car live search
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 05:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 10:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 03:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 08:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 09:47 AM
