Page 75 of 131 FirstFirst ... 25656667686970717273747576777879808182838485125 ... LastLast
Results 741 to 750 of 1303
Thread: LSX (VOID) released
  1. #741
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    ummm just a question but why not use the power button on the lcd? I use mine all the time. just cause i shut the power off doesnt mean the touchscreens off. ive done it like that here and there. and its fine.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
  2. #742
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    thats what i do also, just push the power button, hand is allready there.
    But some people dont have the power button, if they flush mounted there screen and cant access the lcd buttons. So thats basicly why its even there.
    beer replenishment fund
    mp3car live search
  3. #743
    Jun 2006
    My monitor is flush mounted, with no access to the buttons, and its the same with the laptop driving it. So I can't really turn it off.
    The SCF file is a Windows file, have you ever used the "Show Desktop" button - that is an SCF file. I just wanted to link to that to minimize any running apps. I will backup all my files and keep messing about till I get a solution - or at least till you get back. If I figure it out, I will post the code on here for others (if they want).
    Also, the speedo at the top of the screen (in Km p\h) - I assume this is integrated to be used with iGuidance? Is there any chance the code could be lifted from Destinator, or if not, how can I remove it altogether. Is it just a matter of editing the image files and skin files?
    Also, I remember a skin I used a while back where you could search for songs by entering a few keywords. I have about 12,000 mp3s on the computer, and sometimes it takes a while if theres a song I actually want to listen to - any chance of a search function in the future?
    Thanks for the prompt reply, enjoy your holiday.
    '98 Peugeot 306
    Project Status: I sold it ages ago!
    ShutControl
    The ultimate shutdown control software for laptops.
  4. #744
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by blessani View Post
    check your setting in the ini file. you can change it to mph in there. The speed info is not taken from iGuidance, RR pulls it from your gps receiver, you also have to set this in the ini file.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  5. #745
    Dec 2005
    Hey all-
    The skin is really coming along. i have just installed the new skin, and it works great. Just need to know how to use a loadlist as one of the free buttons. Could someone provide a code example to the exectbl or whatever files need to be modified?
    **LS, i just saw your posting on this subject, and saw that you can only open exe files. I should still be able to open a m3u, correct?
    Also, i stream all the time with my verizon card. I have made several M3U lists, and would like to load them from the buttons. However, even if i do this, is there a way to get the (id3) stream to show properly? I have heard that the loadlist command should do it, but i havent been able to see anything but a url.
    Thanks in advance,
    sideone
  6. #746
    Jun 2006
    Ok, I figured out why it was displaying the wrong text - doh! It was a simple line in ExecTBL.ini that still made reference to FREE35 - I changed it now, and it all works perfect.
    I think I'm going to make a few more subtle changes to this skin to suit me a little better. But its probably the nicest looking one out there, great work! Especially since you integrated Freedrive - w00t.
    Anyone know of any software for skin editing for RoadRunner?
    EDIT: No matter, one quick blast on google! and I found this,
    http://guino.home.insightbb.com/download.html
    http://home.comcast.net/~cstrachn/RRSkinEditor.rar
    '98 Peugeot 306
    ShutControl
  7. #747
    Aug 2003
    Chicago
    just got back,
    had no internet access at the hotel so that sucked monkey balls.
    Gonna post an update in a few days, since its Saturday maybe the middle of the week. Got a little skin time in on vacation, but not a lot.
    Ill post up some examples on how to add commands to be used on the custom buttons, but things are gonna change so i may just wait till i finish changeing it.
    But basicly, the way its gonna work, when you are in the audio player, all the buttons will be custom but only allow you to choose from buttons that are related to actual audio except for the top row of buttons which will still be anything you want. That way you can add any missing audio commands you want to use thats not available.
    @ side one, you dont have to use loadlist to load the playlist file.
    Create a folder inside your Music Library, mine is named -{saved list}-
    so its allways at the top of the list.
    Run RRConfig.exe or (from inside the skin) RightArrow>Config>Settings
    Under General Settings>Playlist Path>point to the folder you just created above.
    Put all your playlist files in this folder and they are accessed the same way other audio files are.
    You can also save the currently loaded playlist by click and hold the PLAYLIST button in the audio player. A OSK will pop up and just give it a name and hit enter.
    @blessani
    RRSKineditor is what i use to make the skin. It should be included with your RR install, if not you may have to download it from the RR site. There is also a thread here somewhere with updates to the skin editor.
    also note anyone already editing the skin in RRSkineditor, you may have noticed once you saved the skin, the popup menu is nolonger on the left side, its in the middle. This is because RRSKineditor deletes the values for the menu possition. If you look at the end of the ExecTBL.ini file you should see to pos lines, copy those back into POPUP.skin (before the END)
    Next update the menu will default to the middle and not the left.
    With the redesign of the top info bar, minimize will default back to the TIME button, and the quick menu will be in the middle top of info bar. This ofcourse will all be custom option.
    mp3car live search
  8. #748
    Jun 2006
    LS - skinning and RR question... (Vars and Thumb List)
    LS,
    I tried to PM some of this to you, your inbox is full
    Could you take a look at this, I know you've seen my crazy thread ;
    http://www.mp3car.com/vbulletin/show...516#post901516
    And I am ready and willing to donate as you know even for some assist on this pal. I know you know the VARs as well as anybody as you use them like crazy. I suspect what I am looking to do you could barf out after a good beer night.
    Any help or guidance is appreciated. I am trying it hard to nail myself as well.
    Thanks for anything....
  9. #749
    Aug 2003
    Chicago
    looking
    mp3car live search
  10. #750
    Aug 2003
    Chicago
    I need one person to test something for me.
    PM me for details
    I only have space in the PM box for about 5 messages so first in first out. I only need one person though.
    mp3car live search
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
