unfortunately it looks like that screenshot isnt going to work out
There are several steps that one would need to do to get that screenshot.
Still looking into it though.
beer replenishment fund
mp3car live search
mp3car live search
LS,
I am testing the IG Native beta - could you tell me what my config changes for the stock 1.5 void should look like so I know I am actually using it correctly.
I assume I need to make the change in EXETBL and also in Config...
I just want to be certain I am not using the old external route and seeing it thru the Native code.
Thanks LS
its ok to test the beta with this skin, the next release will be setup to use IGNATIVE by default.
I'll post some info in a bit on what to change to keep things working the way they are but also use the ignative.
mp3car live search
To use the current IGNATIVE beta, first download the beta here
post any issues related to ignative in the ignative thread, but if the issue is isolated to ignative and lsxvoid post it in this thread.
Open ExecTBL.ini found in the skins folder.
Find the IG3 section and replace the whole section with this
The changes are basicly the first two commands, GPS and GPSFS are commented out, then 2 new commands are setup so igcontrol and fullscreen still work.Code:/--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- /IG3 support /"GPS","LOAD;EXTERNAL_GPS.skin;RUN;LSTOOLS\SB2.9_IG3\SKINbedder.exe;SKINbedder||RUN;LSTOOLS\SB2.9_IG3\iGuidance\IGCONTROL.exe" /"GPSFS","LOAD;EXTERNAL_GPS_FS.skin;RUN;LSTOOLS\SB2.9_IG3\SKINbedder.exe;SKINbedder||RUN;LSTOOLS\SB2.9_IG3\iGuidance\EXIT_FS.exe||RUN;LSTOOLS\SB2.9_IG3\iGuidance\IGCONTROL_FS.exe" "EXIT2","RUN;LSTOOLS\SB2.9_IG3\iGuidance\kill.exe||EXIT" "LASTSCR2","RUN;LSTOOLS\SB2.9_IG3\iGuidance\kill.exe||LASTSCR" "QUICKMENU","RUN;LSTOOLS\IG3scripts\torch.exe" "HIDEIGMON","SendMsg;IGMonitor;ShowHideButtons" "EXITFS","EXIT||RUN;LSTOOLS\SB2.9_IG3\iGuidance\IGCONTROL.exe" /IG3 NATIVE "GPSFS","LOAD;external_gps_full.skin;RUN;C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe|nowarning;iGuidance||RUN;LSTOOLS\SB2.9_IG3\iGuidance\EXIT_FS.exe||RUN;LSTOOLS\SB2.9_IG3\iGuidance\IGCONTROL_FS.exe" "GPS","LOAD;EXTERNAL_GPS.skin;RUN;C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe|nowarning;iGuidance||RUN;LSTOOLS\SB2.9_IG3\iGuidance\IGCONTROL.exe" /---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
Next, rename EXTERNAL_GPS_FS.skin to external_gps_full.skin (dont skip this step)
Run RRConfig.exe and under the GPS section
GPS Path= C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
GPS Window Name=iGuidance
mp3car live search
Just a note that the code you posted for the ExecTBL has some spaces in it. So if someone tried to copy and paste it. It would not work.
So, before anyone complains to LS make sure the spaces in the commands are taken out
LS: I was wondering when you were going to add the Iguidance native in RR. I have been following the thread and testing it out with the skin I am making.
mp3car live search
LS -
1 - Other than setup simplicity - could you comment on anything you've noticed good and or bad (your impressions) of iGnative?
2 - Any new goodies coming this weekend ;-) I know you are hiding some goods![]()
