Page 8 of 131 FirstFirst 12345678910111213141516171858108 ... LastLast
Results 71 to 80 of 1303
Thread: LSX (VOID) released
  1. #71
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Quote Originally Posted by liquid_smoke
    this is fairly easy to do. Just remove the album art: Open the skin in RRSkinEditor.exe and on the leftside pane, find the letter J, click the delete button at the top.
    Add your own image:
    Click the Add button on top> select IMG-Image as the object type>Done
    in the following box that pops up, type the file name of your image in quotes like this "myimage.jpg" match the w and h lines to the width and height of your image.
    Follow the same steps to add flash logos also, except instead of the IMG-Image object type, you select F-Flash Movie as the object type.
    all images or flash logos etc must be located inside the skins dir.
    Awsome, now I need to get someone to design the image for me to match the skin. Any takers? I'll send you a picture of my car which is silver BTW! If someone can do this for me and even take care of the above instructions I'll pay them through paypal!! Yes I'm lazy but I'm also very busy!!
    Here's an example of what I'm looking for Acura ITX skin (a work in progress)
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  2. #72
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Well I just got home from school - WOOT business COM is over and I got an A WOOT! Anyway Did some more testing of your skin in the car and on the laptop. I realized that im still running the jan version of roadrunner in the car which could be why some stuff is broken. I don't get the greeting message in the car and the RED speed indicator arrow is missing in the car. Im going to run the may version again in the car just because this skin rules! Also for some reason the GPS full screen exit script is acting up on me now. It was working just fine yesterday and I rebooted and now the litte grey window wont exit the fullsreen mode anymore - the script runs in the systray but it stopped responding or something. Anyway I just wanted to say again this skin is a fine piece of artwork, everything is clean and functional. This release definetly needs more configuration than most but then again its brand new and this is quite typical of a skin this advanced. Anyway here is a screener of my test laptop. The red arrow is what im missing on the carPC but I VOW to get it working and post what i did. Also i don't know whats up with the exit script but im sure ill figure it out. Thats enough talking i need to get back to software config.
  3. #73
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    this skin does require the latest version of RR, so any instability you may be having with basic rr functions may be caused by older version. This is why you dont get the welcome message etc.
    i would also suggest makeing sure you have the latest version of flash installed in the car, the entire speedo on the bottom in the gps fullscreen is flash, so if its loading but elements are missing its likely a flash problem. Also a tip for your igmap , if you look inside of the lstools dir you will find a .exe file special for IG that will make your map look nice and clean like this.
    beer replenishment fund
    mp3car live search
  4. #74
    Aug 2003
    Chicago
    @blk02si and anyone else having issues in fullscreen gps mode, there is a new version of LSTOOLS available, just redownload from same link in first post. This update only changes how the arrow in the fullscreen gps mode works, and also some graphic changes to the flyout menu and a few minor changes to other stuff. So even if you dont have this issue i still recommend to grab the latest.
    mp3car live search
  5. #75
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    LS, love the skin, been using it since yesterday and its great.
    I had one question, is it possible to add a scroll bar to the playlist area. The reason I ask is becuase most of the time I just load all my songs in the play list and if I want to get to a certain song I have to keep clicking. I would be easier if there was a scroll bar thanks.
    also can u add something that differentiates the end of the volume bar and the begining of the track bar?
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  6. #76
    Dec 2003
    New York
    LS, just download the new LSTools and I'm having a couple of problems.
    When I open iGuidance and go to fullscreen, that button to go back does not work. after clicking it, it disappear and nothing happens. It just to work with the old LSTools. btw, I deleted KEYTBL since u said it wasn't needed.
    when I exit navi, skinbedder and IGCONTROL does not close. So I still have the IG menu button in the skin. even after closing RR those two apps still remain open.
    also after doing a mouse gesture in the navi screen, when ever you click a button the skin under igudiance show up for a split sec. the longer u hold the button the longer the screen shows.
    Installed
  7. #77
    Aug 2003
    Chicago
    Quote Originally Posted by Quattro
    humm, ill have to test this out on a fresh box. I changed the way the button that takes u back works cus some people were having problems. Not sure what the problems were it was working fine for months in the oldskin. I prob broke it, not sure, it works flawless on my box. Ill test it in the car tomorrow and on another computer thats never seen RR so that should let me know any issues.
    One thing you can do for me to test something, go to the normal gps screen(dont go to fullscreen at all), then go to this folder
    C:\Program Files\Road Runner\LSTOOLS\SB2.9\iGuidance and run kill.exe
    The flyout menu button should be closed after this.
    If this dosnet work let me know.
    when you exit RR it should shutdown skinbedder if you have it set in rrconfig.exe to close all embeded apps on shutdown. The igcontrol isnt an embeded app so rr will not automaticly close this, thats what the kill.exe file is ment to do.
    ill take some more closer looks at everything related to this issue and resolve it tomorrow.
    Is anyone else having any issues with the latest ver of LSTOOLS and gps? If you had issues before are they fixed with the latest, and if you didnt have any issues do you have problems now?
    mp3car live search
  8. #78
    Aug 2003
    Chicago
    well the track bar is all green and the volume is not, i dont think its hard to tell them apart. They are split right down the middle of the screen also. I played with some other ideas of this before release but didnt like how any of them looked. I want to redesign the sliders to be honest, but its too much work for just a slider, u have to save out like 20 files, gives me a headache.
    as far as a scroll bar for the playlist, not sure thats gonna happen. I understand ur problem though, i too sometimes load the entire playlist but not often. The problem i found when loading the entire playlist and trying to scroll through them its extremely hard to get to where u want to go with a huge list because small movements in the scroll will jump 20-30-50 songs
    you know if you click and hold the up and down buttons they will scroll faster so you dont have to keep clicking over and over.
    mp3car live search
  9. #79
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Hi LS,i'only just updated to the new version of RR and now i'm having album art problems (i've never had album art problems) but its not the skin,it was working ok until this morning.
    The problem i get now is in the audio browser (similar to Picture 2 on page 1 of this thread)
    Half of my album cover has gone missing!!,...Any ideas...it should be easy,its only half a problem.lol
    I will add that the art is ok on all other screens.
  10. #80
    Aug 2003
    Chicago
    this is a bug with the current version of RR, for some reason it seems to only happen to some people as all my album art still shows up. You can read up on it in the bug forum here Highlighted dirs only show a few chars, album art still borked
    mp3car live search
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
