IG2 support is still available in the current release, it just requires a bit of editing where the other gps options dont as much. I think the only real thing you need to change is the file name to IG (remove the UMPC) as everything else is the same. But there are also 2 sets of IG scripts used based on which version your using because of the new stuff in IG3.
This will be fixed up in the next update.
When you run skinbedder standalone does IG2 embed correctly?
If your seeing the file menu and the status bar at the bottom it sounds like your not using skinbedder. Im not even sure right now how things were setup in the old LSX skin (which needs a serious update).
What files did you copy from LSX to LSXVOID, was it just that startup.exe file?
As for updates, they will still be located on the first post in this thread. Editing old post was turned back on.
IG3 is definately better than IG2, so i would update.
Yeah, I should of gotten a ticket for sure, esp after seen so many people walking lines last night. But i used to allways just hear about other people getting warnings for this, warnings for that and allways wondered why. Still dont know why, just glad i finally got one![]()
LinkBack URL
About LinkBacks
