Page 84 of 131 FirstFirst ... 34747576777879808182838485868788899091929394 ... LastLast
Results 831 to 840 of 1303
Thread: LSX (VOID) released
  1. #831
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by yrean View Post
    just noticed a new rr release. im guessing the update is on hold until it works with the new RR update?
    That would be correct. Since ive been using a few of the betas and other stuff in the mean time, the update should come pretty soon still. I reworked the webbrowser last night to support the new native plugin. Ignative is allready done as well as gpsgasnative.
    The current release should still work with the latest RR, you may have some gps issues cause some things need to be changed for ignative to work, but you can just keep the gps stuff set the way it is till the update.
    beer replenishment fund
    mp3car live search
  2. #832
    Newbie WinoOutWest's Avatar
    Feb 2005
    Vancouver, BC
    Removing "starting Winamp" and date message?
    Okay I swear I've searched for this on the forum:
    I found this solution:
    Suppressing the loader screen status reports?
    Which says to modify the loader.skin which I did but it doesn't seem have any effect when I re-started RR. I am still getting the message on top of my splash.jpg.
    Is LSX doing something different for these messages?
    How can I get rid of them?
    Thanks.
  3. #833
    Aug 2003
    Chicago
    Quote Originally Posted by WinoOutWest View Post
    Thanks.
    The purpose of the labels in the loader screen isnt to display the information, but yet give you control of the placement of the information.
    So if you delte the labels, the information dosnt go away (release date).
    If you dont want to see the release version or the status, move the labels off screen instead of deleteing them.
    mp3car live search
  4. #834
    Feb 2005
    Vancouver, BC
    Quote Originally Posted by liquid_smoke View Post
    I had tried that - both moving them off the screen and by making the pixel width 0. I guess my problem was I copied the appropriate line and then added a "/" in front before modifying then and that seems to be my problem.
    All fixed - Thanks!
  5. #835
    Aug 2003
    Chicago
    yeah, the / is the same as delete
    mp3car live search
  6. #836
    Variable Bitrate UM_Fan's Avatar
    Feb 2005
    Miami, Florida. 305
    liquid_smoke
    Couple of newbie questions and more of spoon feeding . 56 pages over 800 post
    The vis you used, where do I put 'em? I got milk drop to work. I've also notice my CPU usage is in the upper 80% sometime going as low as 60% when my using vis..is this common on a via10K (First I used vis)
    Thanks...
    Crazy Miami Drivers
    R.I.P. My first ever NEW Car
    Old installation
    New Install!!!
    |-------------------100%|Cables ran
    |----------------85%----|Software RR
    |--------------80%------|Complete
    [/SIZE]
  7. #837
    Aug 2003
    Chicago
    Quote Originally Posted by UM_Fan View Post
    liquid_smoke
    Thanks...
    i dont use milkdrop(all the visuals look the same to me), the included vis is for the built in AVS in winamp.
    You stick them in this folder
    ....winamp\Plugins\avs
    hight cpu usage is common for visuals, milkdrop probably uses a lot more than than AVS.
    mp3car live search
  8. #838
    Aug 2003
    Chicago
    test
    mp3car live search
  9. #839
    May 2004
    Not sure if this should go here or the main forum, but when I create a Favorites list for XM (in LSX (VOID)), I am able to use the << and >> buttons in the XM menu and it goes through my trimmed down channel list, however when I back out to the main screen with the Favorite section selected, the << and >> sort through the whole XM channel list. Is this a bug or intentional? I'd actually like for it to stay on my Favorites list so I can change channels from the main screen also
  10. #840
    Aug 2003
    Chicago
    Quote Originally Posted by tmar89 View Post
    i have no idea actually.
    I dont have the xm hardware so when i click the Fav button, nothing happens.
    The xm and sirius skins were setup based on user feedback from people who had the hardware and could tell me what what happening when they pushed buttons and if everything worked for them the way they would expect.
    Since really only one person replied to me when i had the xm test a long time ago, the screen is setup based on what they wanted. Ill look into what you're saying above and see what i can do.
    mp3car live search
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
