Page 88 of 131 FirstFirst ... 38787980818283848586878889909192939495969798 ... LastLast
Results 871 to 880 of 1303
Thread: LSX (VOID) released
  1. #871
    FLAC djmickyg's Avatar
    Feb 2004
    Stunning work!
    looks a hell of a lot cleaner now..
    and for anyone getting themself stuck in the lock screen the defult password is 1234
    took me a few mins to work that out..
    EDIT: one thing i have found is the exit button doesnt work? i just hangs RR
  2. #872
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by getyours_2006 View Post
    Really nice work on this new update
    even Iguidance Europe seems to work.
    But the equaliser don't seem to work
    How can I enable it because it's already enabled in winamp.
    Also how can I ad more EQ pre setting
    How do I config the avs?
    Roadrunner had it's own sensor setting
    on a com port is it posible to config this to use the usb port?
    Als I dont have a radio card dont plan to use one but is it posible to config the radio to use shoutcast radio
    doublecheck that the eq is on in winamp, it does work and i havnt touched anything with the eq since the first release of this skin. Testing it now and it works on my end.
    To change the eq settings you have to change it how you want then click and hold on the preset to save it. I think. Its kind of weird how the eq works cuz some of the buttons dont respond to mouse overs like other RR buttons. There may be a faq on the eq also, not sure, but check.
    Sensors: That reminds me that i still forgot to add the voltage labels on the sensor screen.
    As for the "Temperature Sensor Settings" Com Port in RRConfig.exe, I have no idea what that works with or how its supposed to be setup. Im almost sure you need extra software or maybe even hardware for this.
    The skin currently only supports sensor information from SpeedFan http://www.almico.com/speedfan.php
    Previously it worked with MotherBoardMonitor MBM but i think the general opinion was SpeedFan is better and thats what most use.
    Maybe someone else can chime in and say what the builtin sensor support works with. And how to set it up.
    The Visuals are choosein in RRConfig, milkdrop, avs or other this also has to match what vis you picked to use in winamp.
    all other visual options are configured inside winamp.
    There are 2 invisible button on the main menu that will change to the next vis preset if you use AVS as your vis. The are to the left and right of the volume buttons (where the numbers are) will change the vis.
    Also, you have to make sure that winamp is set to use Classic Skins and not modern for use with RR.
    The radio can not be configured to work with shoutcast, its made to only work with physical hardware. You may still be able to use shoutcase radio though directly from the audio player. I havent tried this, but when you load shoutcase if you save the radio station as a preset, the preset should be available for you to use in RR audio browser. For the preset to be available you first have to make sure your path to save presets (set in RRConfig) is set and that it matches where winamp saves its preset files.
    beer replenishment fund
    mp3car live search
  3. #873
    Aug 2003
    Chicago
    Quote Originally Posted by djmickyg View Post
    Stunning work!
    The password for the screenlock plugin is set in Screenlock.ini found in the root of your RR install. You can change the default password there.
    Because there is a 1000character limit on post, i couldnt add everything to the first post, actually had to start removing info just to fit the update text.
    Should of included this in the readme.txt file.
    CDrip has to be configured from the ExecTBL.ini file thats inside the skins folder.
    The reason RR is hanging on you is because there are duplicate QUIT commands in the ExecTBL.ini files, one in the root of RR and the other in the skins folder.
    Open ExecTBL.ini in the root of RR and make sure none of the below lines are present, if so put a forward slash / infront of the line or delete the line completely.
    "CDRIP","PLUGIN;RRCDRip;C:\Program Files\Road Runner\CDRIP\CDRip.exe"
    "QUIT","SendMsg;RRCDRip;showplugin||bye"
    "BYE","QUIT"
    "ONSONGSTART",""
    "ONSKINSTART",""
    these above lines are also present inside the ExecTBL.ini file found in the skins folder and must remain there for the skin to function.
    This is a bug with how RR handles multiple ExecTBL.ini files, and utill its fixed unfortunately this has to be done.
    mp3car live search
  4. #874
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    i dl'd and installed this on the way to work. I must say. good work first of all.
    couple things i noticed. the exit button also on mine. Im gonna go out to the car and check that in the exec.
    then my iguidance isnt coming up. The popup tool bar is i think its igcontrol, but my iguidance dosent come on. I have never installed ignative. I figured it would be somehow incorporated into your lstools or RR. Im guessing I have to install this? im not sure.
    my spectrum vis is no longer where it was but it is down to the left and huge. I had no prob from the lsx void to the lsx1.5 but from 1.5 to 1.6 something changed.
    I tried using the internet browser, but it went to the lsx red splash screen? I didnt have alot of time to look into it, nor could i really while driving. im not sure if anything else is gliched, ill let ya know.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
  5. #875
    Nov 2005
    Maryland
    Quote Originally Posted by yrean View Post
    This is the only thing I can help you with because i had the same issue. On the RR update page it tells you that you must unzip the exe file into the root directory of RR. Initally I had it in a subfoler roadrunner/webbrowser. Void is looking for the exe and can't find it.
    The road runner page also mentioned adding some text to the EXECtbl, specfically : "WEB","PLUGIN;WebPlugin;WebPlugin.exe"
    I'm guessing that is the one in the skin folder because I didn't see that file in this version of RR, might have missed it. Anyway, I didn't do it and it seems to work regardless. So if it is the skin EXECtbl that needs it Liquid Smoke must have taken care of it.
  6. #876
    Aug 2003
    Chicago
    More things i should of added to the readme, some were in the whats new list though.
    Web now only works with the new webplugin from guino thats available on the same site as the RR release. The old builtin web is no longer supported. The new plugin is much better. You have to install this for it to work or you just get the red lsx screen.
    skinbedder is nolnger supported either for IG.
    So ALL skinbedder users will need to reconfigure the GPS options in RRConfig.exe to point only to iGuidanceUMPC.exe or iGuidance.exe and set the window name to iGuidance. The Skinbedder files in LSTOOLS are still present for those who want to manually reconfigure it to work like in previous releases.
    This is not recommended.
    You will also need to add ignative=true in RR.ini
    or false which ever you want, but dont point to skinbedder anymore.
    The vis is by default big now and covers the whole middle area of the skin.
    The only change here is the size of the vis. If its not embeding correctly its probably a timeing issues, RR waiting for something.
    I did a last minute change to the order of some startup things so this may be causeing an issue.
    You also MUST have the absolute latest version of RR.
    Try this file and let me know if it helps any. Rename the file back to ExecTBL.ini (remove the .txt)
    Attached Files Attached Files
    mp3car live search
  7. #877
    Constant Bitrate deus ex machina's Avatar
    Mar 2006
    LS, for a second after I realized that buttons are customizable in RR, I actually wanted to have sex with you.
    I was going to switch to Void for a while, but I dreaded having to rearrange all the screen buttons. That's like half the work of switching skins.
    The blackout feature is something I've used on my own machine for a while. It's even better if you turn off the screen though. I actually have mine set up to turn off the screen, pause the music, and turn on a phigets relay that overrides my ignition wire--keeping my carputer on when I just want to park somewhere for a while. I don't know if there's a command to put the screen into DPMS mode in RR, but this is something Guino could add in a minute.
  8. #878
    Aug 2003
    Chicago
    slow down there buddy, go get a sock, jk, but no seriously go get a sock
    the blackout feature is there mostly for users who don't have access to there power button on the screen because they flush mounted it etc.
    Quote Originally Posted by deus ex machina View Post
    mp3car live search
  9. #879
    Nov 2005
    Maryland
    OSK, CDRip and IG native setup
    First I wanted to mention that the OSK has an issue on all screens that it is accessible. The : and , are switched. Meaning pressing the : gives you a , and vice versa.
    I saw that you mentioned something about setting up cdrip in the exectbl. It is in there for the program but when I run it, it doesn't find the cd drive. What do I put in the set the path?
    I've got IGnative working but have a few questions. Are you going to update the GPS setup faq on page one to reflect the new settings? I have clipping disabled and no longer see the desktop on screen when it loads but it does flash 3 or 4 times before starting correctly and the screen is slightly cut off on the left side. The E in ETA is cut. I am testing this on my laptop and perhaps it will be correct in the car.
  10. #880
    Newbie getyours_2006's Avatar
    Jul 2006
    Netherlands
    The shoutcast radio seems to work that's oke
    Also vis is working but doesn't embed and it takes to much resources.
    Also where can I find this screen
    Last how do I point the file browser to the root of another drive to get this
    And I stil cant get that EQ to work
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
