I installed it, but none of the button graphics are showing up right. All I see is a box with no words outlined. Clicking and holding results with several boxes with no words.
I didn't see anything in the readme about this.
beer replenishment fund
mp3car live search
mp3car live search
Are you new to using RoadRunner? A lot of these issues are common issues that first time RR users have.
If the vis isnt embeding its likely you have winamp set to use Modern Skins, you should set winamp to use Classic Skins. How much resources it takes has nothing to do with the skin, or RR. Visuals are created 100% by winamp.
What version of winamp are you using?
Does the EQ work for you in other skins? And if so what skin?
To browse multiple locations for media, do a search in the RR form for BROWSE.RRL
The screen shot you linked to BBAA (browse by album art) and is the same as when you click the playlist button, except it shows big album art.
the first screenshot you linked is the main menu, you dont have to do anything to find it, its the first screen you see when you run RoadRunner.
This screen has be slightly updated in the release i just posted last night so some of the graphics will not be exactly the same.
mp3car live search
I read it again and didn't see much other than release notes. Where are theses setup steps you speak of?
In the XM playlist screen, the Album art box on the right interferes with the playlist.
In the main screen, there is a box for album are in the left middle part of the screen. In a past post, you mentioned that by removing the J element and inserting an IMG users can put their own image instead of the album art. I did this with the previous version of LSX VOID. In this version I removed the J element again and put my IMG but the No Album Art box is still there. Did I miss something new?
I downloaded the newest beta rr.exe and that fixed my IG3 embedding issue, thank you very much LS.
The menu button: It works but when I click it the entire screen turns pink and the menu button goes into the center of the screen on top of the pink background. What have I screwed up here?
The default large vis: It correctly covers up the middle of the screen as you said but then it also covers up the left/right page buttons. I figured this was on purpose and loaded one of the ALT menus but one of your previous posts leads me to believe that yes it is on purpose but that you should still have the left/right buttons. Is that true?
Browser: More a RR issue but it seems to work with the pages I've gone to (really only google) except mp3car.com It will load the main page but when I click on the forums it freezes and stops responding on that page. It does come up with an error message before it initially loads mp3car about scripts so perhaps that is the issue.
Off topic winamp question: Twice in the last week the winamp volume has set itself to 0% Initially I thought the on board sound had crapped out. I have never had this problem before. What might be causing it?
ok.. so i love the skin but i have some issues it seems. maybe you can help.
I am running your latest along with the 9-5 build of RR.
for some reason IG3 isnt loading still I tried getting it to work but no cigar.
I added ignative=true in rr.ini
igcontrol will pop up, but im still on the main screen. it never launches ig3. im not sure what im doing wrong, but im sure there is a step im missing.
the gpsgas works good, I had a wierd gliche when i was looking for a gas station by zip, but i restarted RR, and i couldnt repeate it.
the web program is pretty cool. It frees up landscape. Any way to get a clock and maybe some audio controls in there? If they were there i didnt see um. Also right now its set to about:blank. Anyway to set the homepage in that?
the FM works good, but it looks like theres a cd in the playlist area behind the writing. also if you go back to the main menu while the fm is playing. the fwd will advace thru the stations but the rew button wont go back.
and the visualization im not sure exaclty where its supposed to embed, but it doesnt seem to be doing it correclty. im running at resolution 800x600 it was fine on the old build. and yes i did try the exectbl.ini you posted. when RR launches it is huge and takes up the whole lower left of the screen until i press top right to remove the spectrum analyzer.
Thanks Ls
Did you set the iguidance path in RRConfig and click the External GPS button?
