Page 9 of 131 FirstFirst 1234567891011121314151617181959109 ... LastLast
Results 81 to 90 of 1303
Thread: LSX (VOID) released
  1. #81
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    ALSO A NOTE TO EVERYONE:
    not sure if everyone using this skin knows or not, but you have to use the version of skinbedder that is included with the skin. So if you were using a different version of skinbedder or its located elsewhere, you need to make sure in rrconfig that your gps is pointed to skinbedder located in this dir
    C:\Program Files\Road Runner\LSTOOLS\SB2.9
    not sure if this has anything to do with the people who are having gps probs.
    IF YOU ARE NOT HAVING ANY ISSUES WITH GPS, fullscreen button, exiting the fullscreen, PLEASE SPEAK UP so i can isolate the issue.
    thanks.
    beer replenishment fund
    mp3car live search
  2. #82
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    I'd heard it had a few probs with art due to changes,funny thing is though it doesn't affect all my skins.Album art is working ok in Bmv2,odd.
    I only updated to test CDR's new skin,between the 2 of you the RR interface is makin massive strides....Any chance of a future collaberation.
  3. #83
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I just did the base RR upgrade from 1-1-2006 version to the 5-2-2006 version and im happy to say that all my issues have gone away! You def. were not lying when you said it needs the newest version. The only thing that still does not work is the full screen GPS speed slider. The red arrow is now there at least! It still does not scroll though. I must be overlooking something. Im going to dig around some more in the LSTOOLS and def. try out that patched iGuidance .exe. Maybe thats why the speed slider is not working?? As far as I know im running the newest version of flash on my carPC because I can use skins with spinning logos with no problem. Anyway just wanted to let you know that im about 95% configured. Thank you for such a great release, but even more thanks to the time you take to respond to all our wonders, requests, and confusions.
  4. #84
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Quote Originally Posted by liquid_smoke
    thanks.
    LS are you saying that when we run RR config under where it asks for GPS path we should put C:\Program Files\Road Runner\LSTOOLS\SB2.9 instead of the regular inav directory?
    Also are you controling the day night mode of IG to just make it night mode all the time? In other words no matter the time of day IG will always show up with night mode?
    Thanks for your help and oh yes you have a PM.
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  5. #85
    Nov 2005
    Midlands
    No i think he means cut and paste the exe over your original in the original directory. (back up the original first though).
  6. #86
    Dec 2005
    Not sure I still follow.
    My Carputer Blog
    Car System Site
  7. #87
    Nov 2005
    Midlands
    No scratch that i think you were right the first time.sorry,i didn't read it correctly.
  8. #88
    Dec 2005
    I'll wait and see what LS says.
    My Carputer Blog
    Car System Site
  9. #89
    Aug 2003
    Chicago
    Quote Originally Posted by blk02si
    are you using a com port splitter? This is also needed because RR makes a connection directly to your GPS device for speed, heading etc. along with iG and since they both cant be connected at the same time you will need to split the com port. Do a search for XPORT on this site and you'll find the port splitter that pretty much everyone is using. Once you get xport running, and have 2 ports that are spitting out gps data, set iG to use one and set RR to use the other one, in RRConfig.exe (or Config button in skin). Also, when you set up the GPS in RRConfig, you DO NOT set it as external, set it to MapPoint, then point the dir to skinbedder inside LSTOOLS.
    are you having any issues with fullscreen mode?
    mp3car live search
  10. #90
    Aug 2003
    Chicago
    Quote Originally Posted by Griff1
    it works fine for me too, i havent tried out any new skins though. Can u send me a screenshot of this, id like to know what it looks like.
    also, one thing i think a lot of people may or may not be overlooking. I dont know if this changed in any of the previous rr releases, since album art has allways worked fine for me. But you need to set/change the dir where your music lib is located for the skin that displays the album art.
    For example, in my skin the album art mode screen file name is audio_browser2.skin
    if you open the skin in RRSkinEditor and go to this screen, on the left side pane you'll see the letters SD, if you double click you'll see a path C:\My Music, change this to the dir where your music is located.
    Again, not sure if everyone knows to do this, it is kind of an odd way to set it up, but if i remove the path i see no album art.
    as far as a colabo, i have no idea.
    mp3car live search
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
