The first issue i see is the winamp version 5.2, ive had numerous issues with this version of winamp in the past. The highest fully working version of winamp i would use is 5.1x, anything higher and issues start to popup.
For BROWSE.RRL
you stick this file inside the root of your music lib
D:\ --THUMB DRIVE--
is valid, but the text THUMB DRIVE is what will show up in the audio browser so you'll want to change it to whatever you want.
I updated the screenshots on the main page and also the faq sections last night, ill do more updating soon.
beer replenishment fund
mp3car live search
yeah, im not sure about the autoupdater, i dont have it so im not sure if it works all the time, ive heard similar things. I know guino sometimes has issues with his host or something like that and new releases go to one of 2 locations and may not have the exact same version on both locals
The best way to check, at least with my skin is the date that you see when you launch RR is the version number for RR.
mp3car live search
yeah the auto updater will say it up to date but that hasnt worked in more then 6 months. you have to manually update the files.
Smoke,
I tried everything you said minus the new exe for RR.
With that said, the smal vis from the ALT folder is working just fine now. Thank You.
the browser, i looked into the webrowser.skin and i seen what your talking about. it doesnt look like what i was looking for. I was looking to make the content text itself bigger. like the CTRL +. Maybe guino will have an answer for that or make the hotkey work.
IG3 now embeds, I still have a flicker, but that wasnt a problem before so it doesnt bother me. I only have 1 issue left with it, and thats theres a black bar on the left hand side that clips about 10 or so pixels. it runns all the way down the left hand side. Im not sure if theres a setting i missed. I didnt have much time to dig deeper then to get it working.
Thanks for your help.
oh yeah and for some reason the wether works fine, but none of the doppler or current radar maps update at all.. is this normal?
and real quick i just noticed this. not sure if you care or not but it looks like you use ig3 also.
http://www.mp3car.com/vbulletin/show...828#post924828
qwerty keyboard for IG3. I wonder if that would be easy to incorporate.
Can you go back and use the BM skin after making the changes in the ini files, or do you have to undo them?
liquid_smoke: You should open up a 800 line for all the tech questions you are getting about the skinNice update by the way.
lol. it is a nice update isnt it :P im just glad hes kind enough to help out on some of these little bugs.
you are one step away my friend
grab the new .exe for RR, it will fix the IG embed black bar on the left issue. Its located in the release thread, ill dig up the post number in a few.
The small flicker is a bug or side affect with ignative and i assume this will be fixed in updates to RR.
The weather dopler/radar scripts may have to be updated, i think weather.com either renamed the files it was downloading or changed the location for them. I havent updated the script in a while because im looking into using a different solution for weather images, same with the traffic button which looks like soon it'll actually do something![]()
mp3car live search
