Page 93 of 131 FirstFirst ... 438384858687888990919293949596979899100101102103 ... LastLast
Results 921 to 930 of 1303
Thread: LSX (VOID) released
  1. #921
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by nyven View Post
    and real quick i just noticed this. not sure if you care or not but it looks like you use ig3 also.
    http://www.mp3car.com/vbulletin/show...828#post924828
    qwerty keyboard for IG3. I wonder if that would be easy to incorporate.
    yeah i saw a thread talking about it, but wasn't aware it was actually taken this far yet, so ill def be looking into that, and yes i am an IG user (cant you tell).
    id also like to know how hes creating the patcher, maybe i can use that to speed up the ig3.exe mod i have so i dont have to manually replace all the buttons/images by hand. I want to do another pass and make some graphic changes to the mod but its soooo time consuming and repetitive.
    beer replenishment fund
    mp3car live search
  2. #922
    Aug 2003
    Chicago
    Quote Originally Posted by 65coupei6 View Post
    liquid_smoke: You should open up a 800 line for all the tech questions you are getting about the skin Nice update by the way.
    For general RR issues press #1
    For lsxvoid issues press #2
    I seem to get both, but its cool, i dont mind. The only thing i don't like is when i answer the same question like 5 times in one day, and sometimes the info is like 3 or 4 post above the person asking the question. That tics me off. But doesn't happen a whole lot.
    Its all good. I really don't mind, long as it doesn't get outta control.
    mp3car live search
  3. #923
    Aug 2003
    Chicago
    Quote Originally Posted by 96TransAm View Post
    Can you go back and use the BM skin after making the changes in the ini files, or do you have to undo them?
    Yes you can still use other skins,
    The way the ExecTBL.ini files work is like this.
    The one in the root of RR is the global ExecTBL.ini file that RR will read each time its launched no matter what skin you use.
    Typically the cdrip stuff would be in this file, but there is a bug preventing me from using those commands in my skin if they are present in the global file, so i had to move them to the one inside my skin folder.
    Each skin, if it wants to use advanced functions and custom commands etc, will create an ExecTBL.ini file in the skins folder that is only used for that skin.
    When RR loads it reads both of these files and is supposed to treat the contents of both files as one file.
    The problem is that when it runs into 2 commands that are named the same, it freaks out.
    For example, the "ONSKINSTART" command that i use in my skin is where all the magic for setting up the custom buttons is started. The definitions in this command tell RR what custom buttons are available, there names and commands associated with them.
    The global ExecTBL.ini file also by default has the "ONSKINSTART" command, but its blank by default and does nothing. So when RR sees both of them, instead of ignoreing the blank command and use the one with functions, it chooses the blank command, and thus none of the custom buttons will work.
    Ill talk to guino about this issue, i posted about it before, but im not sure hes actually aware of the issue since its been a few releases and its still broken.
    The global ExecTBL.ini file isnt installed or included with recent updates anymore, but that only helps if you either are a new RR user or do a clean install of RR.
    So when you load another skin, the only feature you will loose is CDRIP support, which you can add back by adding those commands into the ExecTBL.ini file that is located (or you create) inside of the other skins folder.
    I wouldn't recommend adding it back the root one, unless you dont plan on ever using the void skin again.
    Hopefully this wont be an issue in future updates to both lsxvoid and RR.
    mp3car live search
  4. #924
    Sep 2006
    in case anyone else is having the clipping issue. heres the link.
    RR 9-5-06 .. Native (iG) Gas Update ..
    thanks LS for pointing that out. I didnt see it when i glanced thru. :P
  5. #925
    Aug 2003
    Chicago
    There will be a very small update today that fixes the issues in XM/SIRIUS screens where the playlist is ontop of the album art.
    The updated screens will more closely match how the audio player is layed out.
    also, fix the xm sat sliders are using the wrong sliders.
    There will also be an additional alternative main menu that does not have album art, but a place holder for logos.
    mp3car live search
  6. #926
    Apr 2006
    I downloaded the file and put it in the root of Road Runner, but i can't start up the skin...
  7. #927
    Aug 2003
    Chicago
    Quote Originally Posted by itstdt View Post
    what exactly did you do again, and whats not happening.
    You need to be more specific. Your not supposed to put anything in the root of RR. The skin download is an installer, it should install the skin for you.
    mp3car live search
  8. #928
    Apr 2006
    i get the skin working but there's no button... i have copied the buttons command(? if that's what it's called) to the RR.ini in the root... but it doesn't work...
  9. #929
    Aug 2003
    Chicago
    see this post
    LSX (VOID) released
    mp3car live search
  10. #930
    Apr 2006
    I don't see that file in the root of RR...
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 05:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 10:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 03:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 08:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 09:47 AM
